I want to build an amp that will deliver a bass drum sound for the stomp box I built.
As a 40 year guitarist and repair technician I had to laugh at this until I thought about my younger days of starting out. What I see here is that you made a momentary trigger out of a stomp box that apparently had problems, that you think you can build an electronic bass drum to play it with. Is this correct? See, the amp only gives a bass drum sound ONLY if a bass drum sound goes through it. Amps only provide audio power to the input signal. Where to get you bass drum sound is what you need to find. I believe you are thinking of a sample. A sample is an actual recorded sound of a bass drum that you could actually trigger by stepping on that button. You could find this on most cheaper casio, yamaha, emerson, radioshack, keyboards or drumpads or any of those amateur toys. Most of them allow a trigger pedal to be plugged into it and operational. Now, after you find something with a bass drum sample that you can trigger with your pedal, that device should allow you to plug it into an amp to amplify it. I hope I didn't confuse you much and had a close perspective of what you tried to describe. Please let me know if I can help further.
