it sounds like something internal on the foot switch is shorting out (or a lead wire has come off) or some where in that line , it has been severed. you can check continuity with an ohm meter. butfirst open the foot switch and just give it a visual to see if any leads are severed. you may just need to solder it back. - foot pedals get alot of winding up and unwinding. its common for something to disconnect. that would explain all the issues your having. good luck
First, make sure the jack is not shorting against the circuit board or an adjacent wire. Check the wire connections at the jacks and switch. Sometimes these wires disconnect due to poor solder joints on the switch or jacks. Make sure the circuit board is not touching the enclosure or pot assembly.
I'm not entirely sure what you are trying to do here. Using the left/right panning capability, you can send one mix to the left output and another to the right. You can use the "pre-fade listen" to hear a channel in the headphones without effecting the output.
If you can explain in more detail what you are trying to do, I shoud be able to describe how to do it.
Try contacting their service center rep at (801)566-8800. They might send you a schematic for the pedal if you explain your situation. They do recommend using the original power supply PS0912 which should still be available. Hope this helps.
Try contacting the service center rep at (801)566-8800. They might send you a schematic for the pedal if you explain your situation. They do recommend using the original power supply which is PS0912.
WoW ! Simply remarkable!
I called the company that bought-out BGW in 2003.
"American Amplifiers Inc." California
I talked to Angie who was the best ! she transfered me over to
the Master Tech/Engineer (Larry)
I explained to Larry my problem. He pulled the schematics and we
inspected EACH input /output off the binding posts / large transformer.
21 in all 7 on each side and 7 on top. Larry asked me to identify each colored
wire attached. He discovered the wireing was all backwards and NOT
where they were supposed to be! Disaster in the making! We literally
rewired the hole power grid over my cell phone ! (1 HOUR), double and triple checked each
imput. The subs are back up and thumping hard. (they would be dead without AAI)
AMERICAN AMPLIFIER TECH. INC. IS THE MOST PROFESSIONAL, KIND HEARTED,PEOPLE,READY TO HELP ANY BGW OR AATI CLIENTS I HAVE EVER EVERDELT WITH IN MY (25) YEARS AS A PRO ROAD MUSICIAN!
PLEASE DO BUSINESS with this AWESOME COMPANY :)
Phone: 323-278-0001- ANGIE / LARRY YU D BEST !
Q. (I DREW A SIMPLE DIAGRAM FOR THE BINDING POST WIREING FOR THIS AMP) FREE! TO ANYONE WHO NEEDS IT ! PAY IT FORWARD LIKE FIX-YA!
