Turns on OK with sound but no picture just intermittent vertical coloured lines full picture then comes on fine after about 20 minutes - grateful for any advice
    Sergeant:
  • 208 Answers
That's the board problem, my suggestions is find someone who knows electronic repairing.
Or, if you know what to do, you can re-solder the vertical board, after you open the case, sometimes bad solder cause this problems.
Posted on Feb 19, 2010
6ya staff
SOURCE:
Philips TV turns off and on and has a very bad picture
Check electrolytic capacitors on the power supply board for bulged tops.
May 10, 2010 | Televison & Video
Toshiba rear projection TV 43VH9UA
have toshiba 43vh9ua picture is purple to blue in colour does anyone have a fix... thanks nev
May 12, 2009 | Toshiba 43H72 43" Rear Projection...
Fisher tv monitor intermittently turns to snow and loud buzzing
Could it be vertical IC loose connection. It is sometimes connected with correct tuning. Check it for crack or wiggling connection best is to resolder.
Feb 02, 2009 | RCA Alert Guard 20" Flat Screen 20F670T...
32" sylvania TV thin line
There are bad solder connections on the vertical IC. This is a small flat IC attached to a heat sink. It should have about 9-11 pins and may be marked LA7837 or something similar. Resolder the pins on this IC and that should resolve the problem.
Dan
May 07, 2008 | Sylvania SRT2232S 32" TV
Green and purple vertical stripes on our TV screen
The cause is one or more shorted transistors either on CRT board or on main or both. The colors are red,blue and green, you have a transistor for each and a bias trans. check each there are 6 in all.
Sep 14, 2007 | Televison & Video
No Picture after it's been on a while. Audio OK.
ok you have a vert sweep problem and yes its probably connected to in a way to the "tap and fix" problem! Seems to be n intermittant connection on the vertical out put Ic or maybe even on the rgb convergence ic?? The total loss of sweep though tells me that theres two differant problems! Maybe and intemittant connection on the vert output Ic as well as bad connections on the convergence ic??.
Apr 16, 2006 | Mitsubishi VS-5043 50" Rear Projection...
Televison & Video Logo
103 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
