Service manual. Im in dire need for a service manual for a Ricoh Aficio CL3500N, do you know where i can get my hands one??? I would much appreciate the help. Or if you have one imy error code is SC 441. \ THANKS Carlos A.
Our service manual came in a disc form. Our operating manual has an address & phone number contact. This might help, I don't know. Here it is:
RICOH CORPORATION
5 Dedrick Place
West Caldwell, New Jersey 07006
Phone: 1-973-882-2000
This is usually caused by defective, or empty, toner cartridges. A good cleaning and replacing the old waste toner drum as will as the defective cartridge with a certified manufacturer's cartridge usually fixes the problem.
You can just empty the waste toner bottle. here is what you need to do.
Here is also a manual for your machinehttp://support.ricoh.com/bb_v1oi/html/oi/re/model/cl3500/cl3500en.htm
Detailed instructions on cleaning the Waste toner bottle on Page 32 of the Maintenance Guide. Instead of replacing just empty it. Just be careful as the toner is toxic so you can also vacuum the toner out of the Waste Toner Bottle.
Regards,
You can find the manual here, http://support.ricoh.com/bb_v1oi/pub_e/oi/0001027/0001027180/VG1398503/G1398503.pdf you can find the explanation how to find and remove the wast toner bottle on page 32.
hello there here is several links that will help you out ok best regards michael
RICOH AFICIO220ServiceManual
RICOH AFICIO220 - It's a complete servicemanual, and it's in PDF format. ... i got my servicemanualfor philips vr685-02. Thanks a lot for my very clear and ...www.user-manuals.com/service-manual-RICOH-AFICIO220.html - 73k - Cached
First, check the text in your records for odd characters. It is sometimes possible in data entry to hit a ctrl-"letter" combination that embeds printer codes in your text and these are invisible in many cases to the application. The easiest way is to break up your print job to sections of records and see if a particular record consistently causes an error.
If your sure however that the printer is the problem...
Then I would check the RAM. The printer has 128MB upgradable to 512MB. Normally you can pull the ram and run jobs on the internal memory, but in this case you would need to swap it out.
I have error code SC 441
How do I fix it
Ramona
As posted earlier, printing was going well, then printing stopped with error; SC441.
Did you get a fix?
Please help !
B.
[email protected]
SC 441 error
What to replace??
error code SC 544 appears
