Click on my profile, then click on TIPS AND TRICKS. There you will find link for all Seiko watch manuals. Download yours and learn how to reset the alarm. Rate me, plz.
Pull the crown full out synchronize the alarm time with the main time and press the crown to lock
try with the crown full out to synchronize the time between watch and alarm with the down button.after that press the crown in the correct time.the alarm small dial must follow now the main time dial showing the same time.your watch is ok now.
FIRST SYNCHRONISE THE TWO DIALS IN THE SECOND POSITION CROWN FULL OUT.THEN PUT ON AND THEN PULL ONE CLICK OUT AND SET THE ALARM TIME!THE ALARM ISNT DAILY!YOU HAVE TO SET IT EACH TIME EVERY DAY!THE SETTING IS ONLY FOR ONE TIME WAKE UP.WHEN THE ALARM RINGS THEN THE ALARM DIAL SHOWS THE SAME TIME WITH THE BIG DIAL AND FOLOWS IT!THIS IS BECAUSE THE 7T62 CALIBER CAN SHOWS DUAL TIME THRU THE ALARM DIAL!WITH THE STEM FULL OUT SET THE DUAL TIME IN THE ALARM DIAL AND DONT USE THE ALARM!
Why do I need to 'synchronize' the time and the alarm? I just want to set the alarm to the time that I want.
It seems to work if I pull the crown part out and then set the alarm with the lower button.
But what's the fully out setting for?
And the manual is an atrocious translation and makes no real sense at all...
Here is the procedure to make the alarm time match the you you have set for the main watch time:
2. ALARM HAND ADJUSTMENT
Hour hand Minute hand
B
ALARM
hour hand ALARM minute hand
B Press repeatedly to set ALARM
hands to the time indicated by the
main time hands.
? Set the ALARM hands to the time the main
time hands indicate.
* The ALARM hands move quickly if
button B is kept pressed.
Then press the crown all the way in when finsihed.
Your watch is caliber 7T62. You may download a complete settings instruction manual for this caliber here:
http://www.seikowatches.com/support/ib/index.html
The instructions you need are on page 3 of the manual. I hope this will fix your problem with the adjustments. If you need more help, please let me know.
Regards, Bill
