Epson workforce 610printer offline on wireless home network
First make sure the wirelss is enable and you are able to ping the print server .Go to printer and faxes option and choose the printer model which you installed just right click on it you will see the option of use printer online.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
If your Epson printer says offline, then it is probably the configuration problem. Generally, Epson printers show offline status due to an outdated configuration with your PC. It could also be a software bug that does not go along with the system's configuration or maybe your WiFi network is not strong enough.
Step by Step guide Epson Printer Offline Windows 10:-
Step 1. Press Windows and R keys together to run a dialog box.
Step 2. Type Control Panel and press Enter.
Step 3. Click on Devices and Printers in the Control Panel.
Step 4. A Window box will appear that gives the name of the Epson Printer.
Step 5. Right-click on the listed model and click 'see what is printing.
Want Expert advice - Epson Printer Offline Windows 10
I Hope this Answer will Resolve Issue.
