SECTION 303-05: Accessory Drive
1999 Escort/Tracer Workshop Manual
DESCRIPTION AND OPERATION
Procedure revision date: 06/06/1998
Accessory Drive
Component Locations -2.0L SPI with A/C
Item
Part Number
Description
6B209
Belt tensioner
Generator pulley
Belt
3A733
Power steering pump pulley
5
8678
Belt idler pulley
6
2E884
A/C clutch pulley
7
6316
Crankshaft damper
Component Locations -2.0L SPI without A/C
Item
Part Number
Description
6B209
Belt tensioner
Generator pulley
Belt
3A733
5
6316
Crankshaft damper
Component Locations -2.0L Zetec
Item
Part Number
Description
Generator pulley
19A216
Belt idler pulley
3D673
Water pump pulley
5
6B209
Belt tensioner
6
19703
A/C clutch pulley
7
6B320
Crankshaft pulley damper
8
19A216
Belt idler pulley
9
8620
Drive belt
NOTE: Drive belts (8620) with automatic drive belt tensioners (6B209) do not require adjustment.
NOTE: When a new drive belt is installed or a drive belt is re-installed after a service procedure, the drive belt does not fully seat into the pulley grooves until engine has run for several minutes.
This vehicle is equipped with:
- a V-ribbed serpentine accessory drive belt.
- an automatic drive belt tensioner.
New drive belts must be of the same type as originally installed.
Check the drive belt condition at 96,000 km (60,000 miles) then after every 24,140 km (15,000 miles).
