On the motherboard the pinouts on the front panel should be
colour coded, and marked with letters like in this picture
The
connectors are also marked corresponding to where the connect on the
motherboard, like in this picture >>>>>>which connectors are used for front panel, power - 66ce2fc.jpg src="/uploads/images/66ce2fc.jpg" alt="66ce2fc.jpg" class="h_mi" />
If
the board is not colour coded then the motherboard will marked with the
same letters, you may need a strong light to see the marks.
Regards.
This is Gateway Support, GT5428, and the Front Panel connections on the motherboard,
http://support.gateway.com/s/MOTHERBD/INTEL/4006158R/4006158Rmvr21.shtml
Numbering of the Pins;
Going across the top, start at the upper Right corner.
This is Pin 1.
The pins on top row are numbered Odd.
Starting from the Upper Right corner going to the Left,
Pins 1, 3, 5, 7, and 9
The Pins on the bottom row are numbered Evenly.
Starting at the Bottom Right corner going Left,
2, 4, 6, 8, and 10
1) The two pins in the Yellow are for the Harddrive Activity Lamp. (HDD LED) (Pins 1 and 3)
2) The two pins in the Blue are for a Reset switch.
(Pins 5 and 7)
3) The two pins in the Green are for the Power On light. (PWR LED) (Pins 2 and 4)
4) The two pins in the Red are for the Power On switch. (Power On button. PWR SW1)
(Pins 6 and 8)
5) Pin 9 is a +5 Volt pin.
The Gateway GT5428 Desktop PC, uses a Gateway part number 4006158R motherboard.
Intel made motherboard. Uses the Intel 945G motherboard chipset. Gateway's model name for the motherboard is Coryville. This motherboard uses a 10-pin Front Panel header on the motherboard.
Gateway GT5438 Support Documents;
http://support.gateway.com/s/pc/R/100946...
In the list left-click on - Components
On this page scroll down to the heading - Motherboard, and left-click on -
4006158R - Intel (Corville) 945G Motherboard,
in blue.
On this page left-click on Product Views in the list.
Now go down, and click on, O - Front Panel Connector
