Re: How do i convert a sprint sanyo m1 to verizon...
It can be unlocked by calling your carrier and they will give you the infomation unlock code as long as the account is current and not delienquent if canceled
Verizon WirelessIf you're not receiving calls, callers are not getting through (e.g., fast busy signal, ...calls after turning off Call Forwarding, check additional settings (e.g., Do Not ...
Sprint CorporationTurn call forwarding on or off - Sprint Phone Connect 2. Last updated: Oct 12, 2013. article View all tutorials. Did this solve your problem? Explore Device. Calls.
Usually, all you have to do is call your cell phone number and then you will be prompted to set up your voicemail out-going message, etc
If you are unsure, the best thing to do is, on a secondary phone that is not your cell phone that you want to set up the voicemail, call your cellular service customer support number. This number might be on your cellular bill. They can help walk you through setting it up step by step since each type of phone and phone service is different.
Net10 is a GSM company, which means that the phones that use must have a SIM card. Verizon, on the other hand, is a CDMA wireless carrier, which mean that there is no need for a SIM card in order to work. Verizon and Sprint are starting now to use mini-SIM for some of their CDMA phones or Google phones, (early stages).
Your best option now is to visit a Net10 retailer and asks them this very same question. But I seriously doubt that you can get it to work with Net10.
Net10 use the signals from AT&T, T-Mobile, (Sprint and Verizon when roaming).
alot of 4g phones can't be changed from 1 carrier 2 next,check with ststraight talk & c if they can't convert.my daughters 4g phone couldn't go to page plus,which has chest unlimited plan of all others.verizon carries 4g but little higher,but bout same as straight talk,so talk to them.If ur phone can be converted,take it to kiosk or dealer that does work on straight talk,maybe radio shack.good luck
it is very unlikely but it depends on the type of phone. I have a Sprint phone and the same model phone is mechanically different from verizon's phone although the outside looks the same. I would suggest aasking Verizon but I assume that they would tell you no, even IF it were possible just to get you to buy one of their phones. Try going to www.craigslist.org and search for "unlock" under the services tab Hope this helps..good luck!
it can be unlocked by calling your carrier and they will give you the infomation unlock code as long as the account is current and not delienquent if canceled
If you can get a CS rep to tell you the MSL number yes. Won't help in
all likelihood though since CDMA phones are tied to the provider they
were bought from via the ESN.
