My lg senseclean dd wash dry machine shows the sign CL on the display and the door cannot be open what does it mean? How do I fix this and get the door open? I have tried unplugging the machine and it goes back to the CL and still does not open.
SOURCE: CL on display panel - washing machine will not respond
CL stands for child lock to take it off press and hold TEMP and TIME DELAY at the same time and this should remove it
SOURCE: LG Intello washing machine, model: WD12235 Front Load
Why dont you people read the user's manual? You wil learn abt your machine, to a certain extent. Try "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds. Works for other machines...............And please rate me if helped................
SOURCE: I have an LG washing
CL = Child Lock. Press both WASH and RINSE buttons at the same time and lold for several seconds to unlock (or lock),
SOURCE: LG Senseclean washer dryer combo won't dry
The problem is likely due to lint build up in the condensing unit. I found a solution here:
http://www.motusconnect.com/blog/2009/1/5/lg-washer-dryer-drama-%E2%80%93-diy-fix
I also had a softball size ball of wet, packed lint in the condensing unit. I found that the unit can be cleaned without tools or dis-assembly by:
Happy drying!
