There are a few things going wrong here possibly. Its hard to tell without being able to physically troubleshoot, but here's my guess: blown/no fuse. If your amp's power wire is of top quality, you should have a fuse about 4 or 5 inches up from the battery terminal. If this fuse is blown, no juice will flow through to the amp. If this fuse keeps blowing you have a problem and need to get it fixed professionally or you could risk setting something on fire.
Otherwise, check the amp itself for blown fuses, loose power, ground, or remote wires. Last but not least, be sure that you have set your subwoofer output in your headunit setting menu to ON! =]
