So far as I can tell from HP PartSurfer and the service manual, the only way to change that roller is to change the entire paper pickup assembly. The part number for the latest version is RM1-2755-080CN.
You will need sight of the service manual for the installation instructions as a fairly extensive strip down is involved (all the cartridges, the transfer belt, duplex fan, front cover, output bin, fuser, upper cover, rear lower cover, left cover, and a small bracket and an internal cover along the way). It doesn't look that difficult a job, though it is unlikely that you will chance on the correct installation method without the instructions.
I'm not feeling that happy with HP. My fuser sleeve is damaged; toner sticks to part of it, ruining the printed pages as it comes unstuck. The sleeve is very hard to obtain (I can find some mention of it on Australian eBay whilst I'm in Europe) and there's no instructions to strip down the fuser and change the sleeve in the service manual. Instead, the service manual tells you to fit a complete new fuser and that is the only part listed on PartSurfer.
This leaves me with little other option than replacing the entire fuser, which is in extremely short supply and therefore only available at an elevated price <sigh>.
These are the 2 rollers causing the imprint. Anyone know what this part name or number is called, and what the replacement procedure is? Is it a pressure setting?
Here are the 2 rollers causing the imprint issue. Any idea if it is a pressure setting? Can this bar and rollers be replaced? What is the part name or part number, and repair procedure?
UPDATED PIC: seems it is not the 2 Rollers identified in the previous photo. The culprits are these 2 rollers in the new photo. Anyone know what I can do about the pressure or sensitivity these rollers press on photo paper as it passes along the manual feed tray path? They are leaving imprinted marks on all photo laser paper, regardless how you set the paper source/type in the print settings.
This is the pc showing the roller marks/imprints left on the photo paper. Can anyone help? Anyone? Anyone? Bueller? Please.
