Question about Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television
How do i turn on close captioning on the Sharp Aquos TV when watching a dvd? theres a CC button for close captioning when i flip the bottom part of the remote but that doesnt turn on the captioning when I watch a dvd. i was able to turn it on like 2 times but not able to do it anymore.
  • Sharp Master
  • 8,457 Answers
U want DVD movies captioning,must use the DVD remote control and pick captioning in the DVD movie menu.
Posted on Feb 23, 2010
Anonymous
SOURCE:
I have a Sharp AQUOS LC-32D47UA 32", black box
Press the cc button on your remote control. You want cc to be off. Play around with the cc button to become comfortable. Press it over and over again. Observed that a different closed captioning option appears on your screen each time you press the cc button. Now press cc and when it says cc off do not press the button anymore.
Jan 23, 2011 | Sharp LC-32SB21U 32 in. LCD TV
Sharp Aquos LCD TV 52"
Does your cable company support CC?
Apr 08, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Closed caption wont got off on sharp flat screen
If you didn't already check your TVs MENU for it's CC options and turn them off, Check there first possibly in the Audio Section. Second is check your Cable or DTV Box MENU to make sure that is turned off. With Cable you press the SETTINGS Button and on DTV you press MENU I believe.
Apr 28, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Close captioning on HDMI
The TV will not display closed caption with HDMI input. It must either over-the-air (antenna) or composite input for the TV to manage CC.
To get CC with HDMI from your Comcast DVR, you need to configure the cable box. Instructions can be found here:
http://en.wikibooks.org/wiki/How_to_use_a_Motorola_DVR/Setup
If you want CC all of the time, this works well. But since you must power-off the cable box to change the setting, switching CC on and off is a real pain.
Your set-up is similar to mine (Sharp Aquos 46" and Comcast DVR). I have the composite output from the cable box going to a DVD-recorder and on to the TV. Whenever I need CC (usually to catch some mumbled dialog), I just rewind the DVR, and switch the TV input to the composite input. Then I switch back to HDMI to continue watching in HD.
Mar 09, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How can I active the subtitle and caption for tv programs
My Sharp TV manual says there should be a "CC" button near the upper right corner of your remote control. Keep pressing the button to go through the different options.
Not every TV program has closed caption, so it may not every time.
I hope I answered your question. Please rate me. :)
Mar 01, 2009 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Closed Caption TV
Check your remote for a button marked SAP or CC.
Jul 08, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Close captioning on USA network
You are using cable or satellite, contact them for a resolution. Otherwise the TV is ok and nothing you can do on your end of things. They are probably stripping the CC data somehow on USA network.
Feb 08, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharplc20sh1e
Do you mean the closed captioning or is it the subtitles when viewing a DVD. If it is the DVD then the subtitles need to be turned off on the DVD player. If it is the closed caption and you have a HD Comcast or other type of cable box, then the CC needs to be turned off on that device.
Feb 06, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Turn off closed caption on input(component) on Sharp Aquos 42"
I have a Sharp Aquos 46" and go a Comcast HD receiver as well, and had the same problem turning off the Closed Captioning. I order to turn it off you need to go into the box user setting by (starting w/ the cable box and tv on) pressing the power button for the cable box then the menu button for the cable box. This will open up the user settings menu. Just toggle CLOSED CAPTION to DISABLED.
Jan 29, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-46D64U Large black rectangle in lower half of screen
It sounds like the closed caption text mode has been turned on. Use you CC button on the remote and make sure the closed caption mode is in the off position.
Jan 23, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television Logo
719 people viewed this question
Top Sharp Televison & Video Experts
Ekse
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
