First download the driver & software HERE
but if you a copy of the driver for your lan that will do.
right click on the driver installer (.exe file) > properties > compatibility tab. in compatibility more check "Run this program in compatibility mode for:" then choose from windows xp sp2 or 3 OR windows vista sp1 or 2. (try win xp sp3 first. it works most of the time.) after that click apply then click ok. then check if it works.
let me know if it solved your problem. thanks!
There is available lan to usb you can avail that anywhere
i did not see drivers for the lan card.
