Also, make sure you are using the correct bulb. Using the incorrect bulb can ruin the rheostat.Also, make sure you are using the correct bulb. Using the incorrect bulb can ruin the rheostat.
You can't post conmments that contain an email address.
Faulty door switch, Open dryer door, see if light comes on inside the dryer. If it does the door switch is good. If it doesn’t try resetting the breaker. *( dryer bulbs burn out) you may want to replace the bulb if light doesn’t come on before proceeding forward) The start switch is another cause. You will have to unplug the dryer to check continuity. A broken drum belt. Turn timer on a cycle and listen for it making a ticking sound. You should as the timer is the least likely to fail, from my experience.
May 22, 2007 - 31 posts - ‎24 authors
clicking or buzzing sound coming from the "headlight relay" which is in ... off when you turn on the headlights then it clicks instead of buzzing in that fuse compartment and the headlight flickers about 5-10 times a second in time with the ..... I have a 1992 626 mazda, the battery died and replaced it two days ...
Have a look at the bulbs on the left side when the signal light is on. Are both bulbs on and not flashing or is there just one bulb on? If only one bulb on then the one that isn't on is most likely burned out
Lights are usually on a dual circuit! Left and right have separate fuses, check all fuses or check the fuse diagram on fuse cover or manual to identify correct fuse!
looks like a( DLP) tv digital light proccessor . aka projection. most likely the bulb is burned out . if so cost is $65-125 bucks. aftermarket bulbs are available online but some dont work or burn out prematurely. if you decide to fix it or buy a new tv ,invest in a surge protector. it will save your tv from problems like this . good luck.
Check all fuses under the dashboard, usually on the drivers side for any that are burnt out. The location of which fuse does what, like works the tail lights and brake lights should be clearly marked/printed on the board that conntains the fuses. Replace them if necessary. If that doesn't solve the problem, then check the actual bulbs behind the lenses to see if the 12 volt bulbs have burned out, and replace them if necessary.
Hi, if the light on the switch is coming on, the relay is fine. Unless both bulbs are burned out, the problem is in the wiring between the relay and the lights. I recommend you trace the wiring backward from the passenger side fog light to the power box under the hood to see if the wire is cut. There should be two wires coming out of the power box--one going to each fog light. If the wiring looks good, it is also possible that the ground to the lights is bad.
Look for the easy things first. Could be one bulb was burned out and then the other burned out. Check the bulbs. If that doesn help look at the fuse block, probably under the dash on the driver side. If the fuse is the problem and if it blows when you put in a new one. look in the trunk at the tail light wires to see if they have been damaged or have come loose from the bulb sockets and are causing a short that blows the fuse. Repair or replace bulb sockets and or wires. Good luck.
In the fuse panel with the fuses inside the car there are two big round units plugged into the fuse panel, one is your turn signal flasher one is your hazard flasher. I would start with those and move to other things if that doesn't fix it. Hope this Helps.
