I have a benq DC E610 DIGITAL CAMERA.....now its showing system error 0013 on the screen while switching on...and camera turns off immediately...is there any solution
I had the same problem but now i have solved it.........its not a software problem..... the lens in fornt of the camera is not able to come out......just hit the camera 3-4 times on a table it will start working.......hope your problem is solved
I suggest you tap the camera on your palms. this error has something to do with the camera's lens not able to slide out. our camera was not working for 3 weeks until my mom "gently" tapped the camera and when she opened it, it slid out. hahahaha! good luck guys! the benq camera is great! :D
I have BenQ DC E610, which is showing "System Error 0013" when it is turn on, and it shuts down after this message...please inform me about the remedy via e-mail at
I have a similar problem with my digital cam.sytem error 0013 what will i do to fix this problem?can you help me.
WATS PROBLEM
I have BenQ DC E520, which is showing "System Error 0013" when it is turn on, and it shuts down after this message...please inform me about the remedy via e-mail at [email protected]
?¹???¯? benq ?§???¹?§?µ???© e610 ???§????±?§ ?±??????©..... ?§???¢?? ?¹?±?¶?© ?®?·?£ ?? ?§?????¸?§?? 0013 ?¹???? ?§???´?§?´?? ?? ???? ?§?? ?§?????????? ?¹????... ???¹???? ?§??????± ?¨?§?·??§?¡ ?§?????§????±?§... ???? ?????§?? ?£? ???
[email protected]
i have a benq DC E610 DIGITAL CAMERA.....now its showing system error 0013 on the screen while switching on...and camera turns off immediately...is there any solution
[email protected]
Error 0010 tell you the camera is not fully at reset point when you turn on the camera this is a problem in the lens you must find a way to wind the lens all the way back to its reset poisition.asin the canon sd300 there is a wheel at the top left that you can turn untill the lens is reset.
???¼?°?? ?????¸? ?¿???¾?±?»?µ?¼ ? ?¼?¾? ???¾???¾?°?¿?°???°?? ???µ?½??? ??610. ? ?µ???¸?? ?¿???¾?±?»?µ?¼?° ???°???°.
???·?¸?¼?°???µ ?µ?´?¸?½ ??µ?????°?? ?¿???¾?´?????²?°???µ ??? ??????´?µ?½?° ???????? ?¾?±?µ?????¸?²?° ?¾???¾?»?¾ 10 ?¼?¸?½. ?¸ ??????±?²?° ?´?° ??µ ?¾?¿???°?²?¸ ?¿?¾?½?µ ???°???° ?°?· ???µ???¸?? ?¿???¾?±?»?µ?¼?°.?£??¿?µ?? ?¸ ?½?° ?²?°?.
It works !!!!!! Thank you !!!!! :D
Sirs i have the very same problem and i do not know what do you mean by tapping it on a palm ? , i don't have a palm , please urgently help me please
Thanks i did what ur mother did & it works finally
SOURCE: fawabi
0013 indicates that your camera has a hardware (related to Lens) defect.When dirt gets into the lens mechanism the lens wont retract properly.. You wont believe what i have suggested for a similar problem and it worked! Its a similar lens stuck error..
http://www.fixya.com/support/t240817-camera_error_e45
SOURCE: system error 0013
I have a digital camera Benq dc E610, it showing error 0013 while switching on.
i have the same problem
i also have the same problem. i already returned the camera to where i bought it, they replaced it, and yet it still has the same problem. it's very irritating since i live in the philippines and i have to send it back to my father in greece.
i have a benq DC E610 DIGITAL CAMERA.....now its showing system error 0010 on the screen while switching on...and camera turns off immediately...is there any solution
i have BenQ DC E610, which is showing "System Error 0013" when it is turn on, and it shuts down after this message...please inform me about the remedy via e-mail at
"[email protected]"
Please describe the specifics of your problem below. We'll add
your post as a comment to bansid's system error 0013 benq DC E610 DIGITAL CAMERA problem, and notify you when a new solution is offered
[email protected]
[email protected]
i have BenQ DC E610, which is showing "System Error 0013" when it is turn on, and it shuts down after this message...please inform me about the remedy via e-mail at [email protected]
Kindly help me for my digicam e610 for it has error 0013. I need it badly fo my coming birthday. Thanks and godbless.
Shane
i have a benq DC E610 DIGITAL CAMERA.....now its showing system error 0013 on the screen while switching on...and camera turns off immediately...is there any solution if there is any solution so plz send me mail on [email protected]
error code 0013
Mine does it . too but tapping, shaking, banging or whatsoever doesn't work. By the way, mine is open but won't close...
please help me thanks
[email protected]
please help me in ( [email protected] )
What is the Solution?
