You will require either hacked firmware on a CD-RW or a key sequence input via your remote control or via a PDA with infrared capabilties
http://www.videohelp.com/dvdhacks/sony-bdp-s360/10264
Alternatively, you can use Leawo Blu-ray Copy to remove copy protection and region code on your Blu-rays and DVDs, then copy them to other blank discs or digital copies.
SOURCE: I want to make my
1.Make sure no Disc in tray
2.Press " HOME " on Remote
3.Press Number keys " 1389310 "
4.Power off then Back On
Now try a non-Region Disc
SOURCE: h i got sony bdp-s360 bluray i want to do multi
If it's multi region Blu-Ray that you're after, then you've got a problem as this machine is simply not hackable without wholesale hardware changes inside the machine. The same also applies for most other standalone Blu Ray players from major brand names.
If it's just multi-region DVD playback then it IS possible but not advisable.
You'll need either a service remote (not sold to the general public and very expensive) or an Allsop All-4-1 universal remote control; there are reports that it can also be done using a Nokia N95 and Psiloc software. The links will tell you more.
BUT... it's not advisable. It invalidates your manufacturers warranty/UK Sale of Goods Act protection and my experience of Blu Ray is that there's a good chance that you'll need the warranty at some point. The hack can also go wrong leaving you with an expensive hunk o' junk. Given that you may already have a multi region DVD player and if not can buy a really good hackable model for as little as £25 it just isn't worth doing.
SOURCE: unlock multi region code for sony bdp-s357 blue
Hi, kindly get the code here :
www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
www.dvdreviewer.co.uk/Forums/...region_code/page1
Best Regards, Jay__4r5f
SOURCE: Do you know a region code crack for Sony BDP-S360
Hi there, please get the code here : www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
Best Regards, Jay_3e4r5
