Sounds to me like you need a drum or one of the other routine maintenance items.
The way to find out is to press your machine status button, then look under supplies. You will probably find that a drum life has expired, the IBT cleaning roll or fuser life have expired.
I am sure if you look there one of those "supply" items has reached its end of life.
In the same area under the machine status , there is also a section there for active messages and fault codes. Make sure you look there. If you have additional questions please ask.
If there is an active message or fault code, e-mail me at [email protected]. Just put Xerox M24 in the subject line please.
Testimonial: "Thanks"
First of all sorry if my wnglish is to bad.
First must clean "white band absolutely" which is positioned under the glass sheets on chicken appears when you copy or scan. Loosen the 4 screws that you see when lifting the ADF cover, take the bottle down, and left in a black plastic wipe with a dry area under the plastic. And if you take the bottle down as well to clean and all the mirrors located in the scanner so scanneruls to detect as clear as the light emitted by the lamp.
After booting the machine, it boots only the scan icon is working and copy icon is off, it is not functioning and the message is that some services not available.
