I have HP Laser Jet P3005s Network Printer, I want both side print but printer one side print only i check my printing setting in my computer all setting done plz tell me how ro check in printer setting in printer bar.
By load the toner, if you mean inserting the toner cartridge.Then i will give you instructions.In laser toner printer, there is toner cartridge, and not ink jet cartridge.In laser toner cartridges, there is a black color toner power and it does have any liquid ink, which ink jet cartridges have.To remove the laser toner cartridge from hp laser jet 1100 printer, its simple.The front door open and old toner cartridge comes out.Just pull the front door towards you.While inserting cartridge.If you have problem, then take note that, sticker side of the cartridge is towards you.On the cartridge there is a rectangle flap, which you hold in your hand.This is meant for holding the cartridge, while removing and inserting cartridge.The stick side will be in your side.There is a green color drum, the drum side will be on opposite site.--------------
Still any problem.Keep updated.But i think that will help.Thanks.Helpmech.
USB: Ensures that the USB connection from your computer to the HP product is working correctly.
Network:
Ensures that the network connection between your computer and your
network is working correctly. If the tool detects a network connectivity
problem, you will be prompted to run the HP Network Diagnostic Utility
for better results.
Spooler
: Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
Online status
: Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
Device manager
: Checks for problems in Device Manager that would prevent printing.
Print queue
: Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
Port
: Checks the port settings for the HP product.
Driver
: Checks for alternate-driver settings.
Conflicts
: Checks for conflicts with other drivers, such as other printer brands.
Default printer
: Checks the default printer setting and prompts to select the HP product as default (optional).
Faded prints are possible due to following reasons.
1. Fogged red mirrors inside the Laser box 2. Alignment of the Laser Box 3. Calibration Problem 4. Cleaning Problem
I will guide you with simple steps first, if this dosen't work working with laser box is little tough & time consuming, hence will describe later.
To Calibrate the colors, Press the 'Green Button' in the front panel, use the arrow keys to navigate through menu.
Select 'System Setting' by pressing the green button again, navigate using the arrow keys and select the 'Calibrate Color', select green button to select and confirm to 'Calibrate Now'. This will take few minutes.
In addition to that, to clean the paper path, select the green button and use the arrow keys and navigate thru' menu and select 'Service'. select using the green button and navigate through menu and select cleaning option. This will take few minutes.
Try printing some documents and check whether you have fixed. If you have not got the original print quality, Let know to guide you more technically.
You have to print the first side then take those prints and put them back into the paper tray to print the second side (Manual Duplex). If this were a DN model it would have built in automatic duplexing and you cound select "duplex printing" from your print setup screen and the printer would print both sides automatically.
This document provides information about replacing the print cartridge for the HP LaserJet 1010 printer series, including life expectancy and replacement instructions.
Print cartridge life expectancy
The life of the print cartridge depends on the amount of toner that your print jobs require. When printing text on letter/A4-size paper at five percent coverage, the print cartridge lasts an average of 2,000 pages. This assumes that you set the print density to three and disable EconoMode. (These are the default settings.) See Ordering supplies for information on ordering replacement print cartridges.
Changing the print cartridge
Follow the below instructions to change the print cartridge:
Open the print cartridge door, and remove the old print cartridge. See the recycling information inside the print cartridge box.
Figure 1: Removing old print cartridge
CAUTION:
To prevent damage, do not expose the print cartridge to light. Cover it with a piece of paper.
Remove the new print cartridge from the packaging, and gently shake it from side to side to distribute the toner evenly inside the cartridge.
Figure 2: Gently shaking new print cartridge
Pull the tab until all the tape is removed from the print cartridge. Put the tab in the print cartridge box to return for recycling.
Figure 3: Removing tape from print cartridge
Insert the print cartridge in the printer, making sure that the print cartridge is in position. Close the print cartridge door.
Figure 4: Inserting new print cartridge
HP LaserJet 4700 printer comes with inbuilt network card so you don't need to install another network card. If you want to but network card for your PC then go for 100/1000 Mbps network card.
i am an expert in a different catagory,...
but i read your problem accidently and i had the same problem with my laser jet..
check the order list (in you PC screen in the right end of the START bar there is a little printer ...)click on it
and if you find a printing order of a blank page delete it...if not
then its not the same problem and am sorry i can't help any more..
The standard port settings used when setting up a Printer Port is Port 9100 (TCP) when normally communicating with the Jet direct / LaserJet 4 plus printer. However when using the Emulex Card it s default is Port 2501 (UDP). So within XP change the Port setting to 2501 and it then will communicate correctly.
