Question about Zebra Z4Mplus Label Printer
I have a Z4mplus printer that prints a label then the pause button comes on. If you release the pause it will print the second copy of a 10 copy label. This goes on randomly, any thoughts?
  • 16 Answers
Sounds like you may have it set for "peel-off" mode instead of "tear-off" mode.
Posted on Mar 05, 2010
6ya staff
SOURCE:
When I send a print job to my Z4MPlus label printer, the label prints but without any ink on it. It is set to Direct-Thermal. What else should I be looing for to correct this issue?
Hi, you can have 3 scenarios here, the print head is faulty, mainboard faulty or darkness set to low, please reset printer to factory default without any lpt/com/usb/network cables connected, turn off and on. try to run Pause test ( turn on printer with pause button pressed for 5 sec and release it)
Feb 21, 2015 | Zebra Z4Mplus Label Printer
Z4Mplus test page
Do you want to print out settings? Do you want to print a printhead check? Make sure supplies are loaded and the printer is ready to print. Turn off the printer, press X button, turn on the printer while pressing de X button and release the button after aprox 5 seconds from power on. This will print out the configuration page. Do the same but with the Pause button, and you will get a printhead quality test. Note that the test with Pause button it will stop automaticly only after some 10 printed labels . You will need to restart the printer after that, or press the cancel button several times.
May 06, 2014 | Zebra Z4Mplus Label Printer
Hello, I have a problem with Zebra Z4M Plus
Hi, if is the vertical line, its the print head that need to be replaced,
try to clean the print head and try this to confirm:
turn printer off, press PAUSE button and at the same time, power on, don't release the button, please wait until printer LCD screen come on, then release button. It will print the PAUSE test and after few 3-4 prints, u can turn off and on again otherwise printer not ready to print your labels until u restart it. (pause test stops after 10-15 labels). this pause print just show how the print head is and if come with vertical lines, u will need to replace. other idea is (if u can) turn the bar code different position or on vertical way at label format. Thanks.
Aug 04, 2013 | Zebra Office Equipment & Supplies
We use 2 column lables and when we print the barcode on the second side will not scan. there is missing lines in the barcode.
possible, need printhead replacement. Try to.
Turn printer off,
press pouse button,
turn printer on, still pressing pouse button for 10 seconds, and then relese the button. the printer will print the pouse test with barcode, check if coming with wihte lines across, if yes, change printhead.
Mar 03, 2011 | Zebra Z4Mplus Label Printer
Z4m printer problem
You may have an element or two on the left side of the printhead that is worn out and not printing. The best way to see if elements are not working is to use the widest label you have and run the PAUSE test. Turn the printer off, press and hold the PAUSE key while you turn the printer on. Keep pressing for about 10 seconds and then you can let go. When the printer is finished starting up, a test pattern will print. Part of the pattern is a black box. Any elements that are not working will show as white vertical lines. The only way to correct is to replace the printhead.
Hope that helps !
Jun 09, 2010 | Zebra Z4Mplus Label Printer
My Zebra Z4m plus start to print in middle of the label,but suddenly to appear next message. error de papel.and stop the machine and the print on the label is in wrong positions
The label is not calibrated. Press keys FEED, PAUSE and CANCEL, turn the printer and release the keys when making the labels. Also verify that the type of material is NOT CONTINUOUS.
Roberto Martinez
Sep 28, 2009 | Zebra Z4Mplus Label Printer
During manual calibration of the Z4Mplus the
Let the printer calibrates itself or have a manual calibration in the printer setup. You can also press the keys FEED, PAUSE and CANCEL, turn on the printer and release the keys when feeding the labels.
Roberto Martinez
Jul 07, 2009 | Zebra Z4Mplus Label Printer
Stops printing after sending job
try to reset to factory defult,
run calibration and sensor profile.
if dont help,
it is possible that the power suply or logic board is faulty.
Jun 30, 2008 | Zebra Z4Mplus Label Printer
Zebra z4mplus
iN THE DRIVER CHECK THE head TEMPERATURE ISSUE. Most certainly you do not heat enough to do the transfer.
Else your ribbon is not mounted correctly. Zebra has an out inking transfer film
May 21, 2008 | Zebra Z4Mplus Label Printer
Manual calibration of labels not working, printer not feeding labels correctly
printer manufacturers has different standards depending from the varieties of model and brand of printers for example an epson printer model who is older version is not the same speed print with the recent model likewise with the other brand. Therefore calibration of labels is depending to the version of the printer you are using now.
Apr 22, 2008 | Zebra Z4Mplus Label Printer
Zebra Z4Mplus Label Printer Logo
332 people viewed this question
Top Zebra Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marvin
Marvin
Ekse
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
