What Brand and Type of phone ??..
Phone password or google account password ??..
Im thinking iphone ?
Although a passcode limits your iPhone to authorized use
only, protecting your vital personal information, if you forget it, you can't
use your phone until you enter the correct code or revert your phone to the
default factory status.
Apple provides ways to resolve a forgotten passcode problem
and improve the iPhone's security.
Wrong Passcode
When you enable iPhone passcode security, the phone
requires you to enter the code to display the home screen.
By default, when this protection feature is enabled, you'll
be prompted to enter the passcode to turn on or restart the iPhone, wake it or
unlock the screen.
When you enter the wrong passcode, the "Wrong Passcode
try again" message appears onscreen.
If you enter the incorrect code too many times, the iPhone
will lock automatically and display the "iPhone is disabled, try again in
1 minute" message.
This disabling security feature is designed to protect it
from unauthorized tampering.
If you keep entering the incorrect code, the iPhone will be
disabled for a longer time.
Restoring iPhone
If you don't remember your passcode, unfortunately, there
is no way to retrieve it.
Apple says that the only way to solve passcode problems is
to restore the iPhone with iTunes.
Before restoring the phone, downloading and installing the
latest version of iTunes will improve connection and decrease the chances of
errors.
Unfortunately, restoring the iPhone erases saved content and
clears custom settings, so create a backup copy of your files with iTunes
before proceeding.
From there, you can restore your iPhone by clicking the
"Restore" button on the device's "Summary" tab in iTunes.
When the process completes, you can change the passcode
settings.
Changing Passcode Settings
iPhone allows you to not only create a new passcode, but
specify the amount of time it should take before the screen locks after
inactivity.
You can also specify whether you want to use a simple
four-digit passcode or a longer one that can include letters and numbers.
Tapping the "Settings" icon on the home screen
will bring up the phone's settings.
From there, tapping "General" and then tapping
"Passcode Lock" will bring up the "Passcode Lock"
customization screen.
Select the settings you want to use to protect your iPhone.
The changes will take effect immediately or when the iPhone turns off.
Tips
After restoring your iPhone, create a passcode you'll
remember easily.
While creating a longer passcode can increase the security
on your phone, you can forget it easily if you don't write it down and store it
in a safe place.
gmail password reset
Open the Web browser on your phone and navigate to
gmail.com.
Tap "Can't access your account" located under the
"Sign in" button.
Select "I forgot my password" and then click
"Reset your password here."
Type your email into the "Email" text box and then
type the random captcha into the captcha text box.
An email with your new Gmail password will be sent to your
alternate Gmail address.
Follow the directions in the email to reset your password.
Type the new Gmail password into the loin screen on your
Droid to unlock the account.
http://www.gmail.com/
