Question about Makita Hm1500b 42-pound Demolition Breaking Hammer
What type of oil i will luricate to my makita HM demolition breaker
  • 285 Answers
Demolition hammers require hydraulic oil in most cases.
Any good tool shop should have hydraulic oil to suit.
Posted on Feb 25, 2010
  • Makita Master
  • 2,015 Answers
A-90582 Hammer Grease is used for the younger tools with more rpm
or P-08361 in the older models thats black colored graphite grease they have other rings instead of o rings its not an high rpm tool
but if more rpm most little machines oft more using a liquid zinc-free hydraulic oil Hilti and Bosch rotary hammers some lifetime filled pressurewashers have that kind of oil too because of the aluminium housing and other parts to avoid galvanic reactions between different metals
Posted on Apr 24, 2017
What type of oil shall be used in makita hm1304 demolition hammer?
You require Hammer Grease, All good tool shops should have grease to suit. see link below:-
Hammer Grease 90582 for Makita Power Tool eReplacement Parts
Feb 11, 2016 | Makita Hammering
Type of oil use for demolition hammer
A old black graphite or yellow grease lubrication of the brand Makita
Apr 29, 2014 | Makita Hammering
What type of oil
http://www.homedepot.com/p/Makita-Hammer-Bit-Grease-194683-7/205182387
For outside chisels
Inside its depend on the model but most time its a Makita 181490-7 or for the older types Hammer grease Makita P-08361
Feb 19, 2014 | Makita Hammering
What grease do you use for a makita demolition hammer
MAKITA HAMMER DRILL GREASE 30G (181490-7) or for the older HM models Hammer grease Makita P-08361
Nov 05, 2012 | Makita Hammering
I have a makita hm 1810 hammer green light stays on hit switch light goes off
As stated in the manual:
The green power-ON indicator lamp lights up when the tool is plugged to the mains. If the indicator lamp is lit but the tool does not start even if the tool is switched ON, the carbon brushes may be worn out, or the motor or the switch may be defective. If the indicator lamp does not light up, the mains cord or the indicator lamp may be defective.
Aug 25, 2012 | Makita HM1810 Electric Demolition Hammers
Where do I ad oil to a makita hm1500 demolition hammer
Go to http://www.makitatools.com/en-us/Modules/Home/Default.aspx, put your model number in search box in the top right. Two models of the HM1500 will come up, select yours and open the owner's manual. Find the paragraph labeled 'Lubrication' and follow it precicely. Demo hammers are very picky about what type of grease they use and how much. Too thick and they won't work, too thin and they won't lubricate properly and the parts inside are very expensive to replace. Same applies to how much to use.
Jan 20, 2012 | Makita Hammering
What kind oil use for makita hm 1304bx1
What kind of oil is used in a Makita Demolition Hammer?
Oct 01, 2009 | Makita Hm1304bx1 Demolition Hammer +...
Makita Hm1500b 42-pound Demolition Breaking Hammer Logo
2,429 people viewed this question
Top Makita Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Andrew Taylor
Andrew Taylor
Are you a Makita Hammering Expert? Answer questions, earn points and help others
