Whirlpool Duet GHW9150P Front Load Washer Logo
Allison Collier Posted on Mar 02, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whirpool Front Loading HE (GH9400PW4) washer is leaking! Hellllp!
Well, it leaks all of the water out of the bottom during the draining period after the wash. It seems to be coming from the bottom. I was told to check the soap drawer for clogs. It isn't. Any other sugesstions?
  • dfunk era Mar 02, 2008
    my whirlpool front end load duet washer is leaking as well. During the rinse cycle the water level will rasie and then transfer to the door itself causing a pool like effect of water on the bottom quater of the door. From there, the water leaks out the bottom of the door and into the base of the washer. Then onto my floor. Any suggestions, I think I need a new seal for the door itself or a new door. Thanks.
Ron Coons
Level 3:
President:
  • Whirlpool Master 2,651 Answers
  • Posted on Mar 02, 2008
Ron Coons
Whirlpool Master
Level 3:
President:
Answers
2651
Questions
Helped
1546846
Points
7824
Remove the bottom acesss panel and run through drain/spin cycle youll see where the leak is then. perhaps debis has puntured drainline hose or pump housing is leaking
My whirpool WFS1071BD front load washing machine leaking when spinning
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find.
2answers
Maytage MAH6500AWW Overloaded washer now leaks when filling
since you can drain it
take off the back and watch what happens when u turn it on
i believe you make have a loose drain connection
1helpful
Roper washer leaks when filling
It's in the drain hose somewhere,during the fill the water gets as deep in the drain hose as it does in the washer,during the wash the pump runs in reverse keeping the water level in the hose low,during the drain the hose is filled again.
Prop the washer up in front on a couple bricks or boards,start putting in water until it starts to leak and take a peak under the machine.
1helpful
Drain hose seal leak on Kenmore washer
Remove the hose and bend it in circiles see if yo see any cracks in the hose if you do replace it or if it's long enough cut out the bad part and replace it. Alos clamps wear out ver time so try replacing the clamps too.
1helpful
Front bottom leak from my LG TROMM HE Washer
  • Hi
  • Try these:
  1. Inspect the water supply connections
  2. Inspect the drain hose
  3. Inspect the water pump
  4. Inspect outer tub for cracks or corrosion
  5. Inspect the tub seal
  6. Inspect the tub bearing
please rate my suggestion...
Whirpool Duet Sport Washer still making noise now it s leaking
make sure to look really close all it takes is alittle whole in that seal anywhere to cause a leak try to look close while it is running but first dry everything you can and then run it. also make sure your door glass is clean if it is leaking down the front just alittle dirt or hair can cause a leak aswell
Leak well after completion of wash cycle - Neptune Front Loader
peace,
ngafm1 at your service,
Water sprayed out of ( the leaky washers in the hot water shut off valve which need to be replaced.
They are inside all valves and wear out in time from normal use!
Or you can have a bad solder joint at the junction between the hot water shut off valve or the the pipe joint!
these washers in any shutoff valve can leak intermittently till they get worse and then leak all the time!
you should be able to stand there and watch it as you open and close the shut off valve again and again , and then stay there and watch it start leaking!
Or when you are opening it and closing the valve 4 times straight you may feel a trickle of water from the valve stem!!!!
This means washers in the valve stem need to be replaced!!!
Get a new plumber !!!!!!!!!!!!!!!!!! I'm no plumber but I do under stand this!
Bless You,
please give me a good rating here at fixya.com before you sign off!
Neptune washer
check arround the rubber bellows that the door seals aginst, maybe a hole in it, could be a pump leak drain hose leak
a lot of could bees i know but one of these
Whirpool Front Loading HE washer is leaking! Hellllp!
hi there i would check the softner part of your soap drawer first for blockages, you can let me know
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
