Question about Kenmore HE2 Plus Front Load Washer
Front loader kenmore he2plus rocks the house on spin cycle?
Spin cycle The washer is shaking and shakes objects off dryer?
How do you control this?
    Champion:
  • 207 Answers
Make sure the unit is totally level on all4 corners if this dont cure it make sure there arent any shipping bolts toward the bottom that were supposed to be removed after installing that are still on them they will have a yellow or red tag that will say remove after shipping hope this helps
Posted on Feb 25, 2010
  • Lorenzo Lynn
    Lorenzo Lynn May 04, 2014
    Yes check the back of the washer for 4 bolts or shipping bolts. Also is is making a roaring noise?
6ya staff
SOURCE:
Drum knock when spin cycle
Hello.
Noises are common when using a two-in-one washer and dryer, as clicking or whirring is part of the cleaning process during the transition to the next cleaning process. The GE Spacesaver washer and dryer combo uses a top-loading washer stacked beneath the front-loading dryer, and uses an agitator that makes noises throughout the spin cycle. Although whirring or clicking is normal, other noises or malfunction indicates a problem with the washer that requires minor troubleshooting. Professional repair is necessary if the washer continues to experience problems during the spin cycle, as there may be a problem with the washer's agitator.
1 Open the washer's door and check the balance of the load's clothes. Clothes that are unevenly distributed around the agitator cause excessive shaking and result in an imbalance during the spin cycle. Reduce the load's size by removing clothing if the washer's drum is overloaded.
2 Push "Start/Pause" to pause the spin cycle and turn the washer's cycle knob to the "Off" position. Turn the knob to "Spin Only" and press "Start/Pause" to reset the cycle.
3 Turn the wrench counterclockwise or clockwise around the unit's legs to adjust the appliance's balance. The legs are adjustable with the help of a wrench to ensure the unit does not shake while in use. An unleveled unit shakes as it spins, and causes excessive squealing or rattling as it attempts to dry the clothes.
4 Touch "Start/Pause" on the front of the washer's control panel and unplug the washer/dryer unit's power cord from the electric oultlet. Wait two minutes and plug the power cord back into the electric outlet. Push "Start/Pause" to resume the spin cycle.
Thanks.
Nov 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Stackable washer and dryer. The dry shakes when the washer is on spin cycle.
The washer spins real fast and can shake like he**. The load can also be unbalanced.
Jun 14, 2010 | LG WM3431 Front Load Washer / Dryer
The washer shakes violently during rinse/spin cycle, Probably from loading too heavy of a load,what can i do?
take out the heviest object put it back in evenly by it self .or cold be broken stabilizer spring.cold be laying inside the botum of machine.adjust legs.
Jan 25, 2010 | Kenmore 80754 Top Load Stacked Washer /...
Samsung P801 Front Loader shakes violently during spin cycle.
When the washer goes into spin cycle it is suppost to start at a slow speed and continue to increase speed (to a maximum of 800 RPM) as the water leaves the clothes. Your washer is going directly to 800 RPM which causes the washer to shake and stop giving you the E4 code. The control board that controls this speed increase must be replaced.
Feb 23, 2009 | Hotpoint Ultima WD72 Front Load...
Washer is shaking violently when it is time for the spin cycle
Hi you must make sure its level in all directions. ie front to back and side to side. Alos dont overload it. If its on a wooden floor it will vibrate. A concrete floor is the best
Feb 15, 2009 | Washing Machines
Check to see if all shipping blocks and bolts were removed. Refer to installation and setup instructions for your model.
I once moved into an apartment furnished with washer and dryer. The washer had worn holes in the vinyl flooring and a neighbor said the previous tenant made her son sit on the washer to hold it down. I investigated and found the shipping bolts were still in place. The tub, which is supposed to be able to swing, was rigidly held in place, so the entire machine danced around the room!
Jan 10, 2009 | Frigidaire 14 Cycle Tumble Action Washer
Rattling noise during spin cycle
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
Our washer shakes badly at the spin cycle
Please look in the back see if the shiping bolts /rods have been removed it should show you in the manual about this
Jan 03, 2008 | GE WCVH6260F Front Load Washer
WAY too much shaking
Take out the four "shipping\travel" bolts in the back of the machine. Read the manual- it will tell you how to do this. John
Apr 29, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Kenmore HE2 Plus Front Load Washer Logo
474 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
