If you're trying to change the channel, it's the last 2 buttons on the side of the tv.
If you're trying to scan for additional channels you'll need a universal remote.
based on what the manual says you need to press the "menu" key to do a manual channel search. unfortunately there is no menu key on the side of the tv.
Universal remote alway work only the basic for the tv.Beyond that will have problems or stuck in some input or modes.Sorry i can't help u, because i don't know what is the reaction to ur tv by the universal remote,must use the universal remote again tries all the buttons like video modes or input botton.Or take the battery out like 20 mins of the universal remote to erase ur tv codes enter it again.Tries those buttons u pushes before,see if u can get out the video mode.All else fail.Try website like Remotes.com to buy the tv original remote to use.
most universal remotes will not operate menu fuctions or allow input selections. try using channel down buttton on tv . go all the way down to channel two then go down again to see if video1 or 2 comes up. if not access menu functions on front panel go to input select enter in manually mch
sanyo ds35590 no remote, tried universial remote still cannot select menu on uvm. What remote do I need? Or can I get into the menu without remote. I am trying to watch a dvd.
Yippie, I figured out a solution that worked!!! I have a univeral remote from comcast, on that remote near the bottom left is a small button that says (input) tv/vcr, press that one time and whala!! the tv video screen was gone, I had to manually change the channel from the tv channel button on the unit. once I changed the channel to 3, my universal remote worked... the button is the second one from the bottom left... I was on hold with sanyo for a long time and just kept trying on my own, so good luck!!!!
ok i have a sanyo tv that was set to imput my remote messed up but now it is fixed i cant figure out how to get it off. in order for me to reprogram my Universal remote i have it has to scan channles right wut do i do??? plzzz help me!
The only way your going to change the video mode is with the original remote. If you need another remote go to http://remotes.com or call 1800 remotes Theres a button on the upper left hand side of the remote called video mode. A universal most of the time will not work this function. You could ask around to your friends and buddies or relitives if anyone has a working Sanyo remote or go to a local retailer that sells Sanyo and see if he would let you borrow one for a little while so you can switch out of the video mode. Good Luck
