Toshiba Satellite A215-S7422 Notebook Logo
Posted on Feb 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Toshiba laptop will keep shuting off - Toshiba Satellite A215-S7422 Notebook
Anonymous
Level 2:
Scholar:
  • Expert 114 Answers
  • Posted on Feb 26, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
114
Questions
0
Helped
18256
Points
269
It is because of the laptop overheating problem. This is a very common problem with and could be easily fixed if you clean the heat sink. If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
(If this tips helpful please rate this solution)
NP350E7C-A01US samsung laptop windows 8 keep shuting down after 5 mint or some time 10 mint .
I'm having the same kinda problem but it's random or sometimes it duzent Finnish booting I know it's not over heating iv COMPLEATLY taken it apart and cleaned everything and applied new artic silver paste... and the ram is fine.. I have tested it in a nuther laptop.... It duz this on both battery and ac power.. Any clue what it could be?
My computer keeps shuting windows down
Hi
Shutting down like this is usually one of two things - a hardware fauld which needs to be tracked down and corrected - or a system/driver fault. The latter usually requires reverting to a restore point before the problem started, or re-installing the drivers or updated drivers. Without a lot more information on your system, and when this usually happens, it is impossible to be more specific.
1helpful
My toshiba m55 satellite s3294 keeps shuting down unexpectedly I hear the fan when its on and I cleaned the fan recently I even reinstalled windows but it keeps doing it is there anyone who can give a...
please RUN the software diagnostic coming with your PC, or download from your supplier manufacterer from FREE. YOU can have faulty 1) power supply 2) motherboard c) fan DEFEctive. d) Ram faulty or dity.
God bless you
2answers
Computer keeps shuting down for days at a time
Needs servicing. Sounds like a bad motherboard or corrupt drive, what are the error messages besides the obvious fan malfunction?
Laptop keeps shuting down at random.
This could be caused by MANY different things. If it is a random thing, where do you have your laptop when it happens? If it isn't on a flat smooth surface, it's probably a heat related issue. Laptops need a lot of air circulaton, through the bottom.
My puter keeps shuting off
Might be an overheating problem.
Cleaning Fans and Troubleshooting Hot CPU Failure
http://www.fonerbooks.com/lap_fan.htm
Laptop keeps shuting off
how old is the system
is this while running with ac adapter or battery or either
Toshiba flash cards " not Responding"
Dear Sear
First of all i aprechiat your willing to offer me a solution for the problem (flash cards are not responding).My laptop has thise model; Toshiba Satellite A200 - 1 GB - intel(R)Core(TM)2 CPU T5300 @ 1,7 MHz.
I solved the problem just with shuting down the mashin, that's all.
I thank you indeed for you respond and i'm looking forwards.
Best regards
Yours
Aweti.J
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
