Radio Communications Logo
Posted on Feb 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Midland alan 42 multi CB Radio
Instruction manual lost
How to you change from EU to UK channels
RandomAdvice
Level 2:
New Friend:
  • Expert 67 Answers
  • Posted on Feb 27, 2010
RandomAdvice
Expert
Level 2:
New Friend:
Answers
67
Questions
0
Helped
23306
Points
176
The user manual can be found in PDF form here: http://www.alan-uk.com/cb/manuals/42%20multi%20manual.pdf
normis101
Level 2:
New Friend:
  • Expert 69 Answers
  • Posted on Jul 10, 2016
normis101
Expert
Level 2:
New Friend:
Answers
69
Questions
0
Helped
21145
Points
173
Try the Alan-uk.com website and download.
Midland cb radio 40 ch transceiver
Here you go
OWNER'S MANUAL midlandusa.com - Midland Radio
https://midlandusa.com > uploads > 2016/12 > 75-...
PDF Midland 75-785. 40 CH AM HANDHELD CB TRANSCEIVER. 78-785 is a 40 channel Citizen Band Mobile operation, that is big on performance.
15 pages
HANDHELD CB RADIO - Midland Radio
https://midlandusa.com > uploads > 2012/06 > 75-...
PDF Sep. 10, 2012 - Midland 75-785. 40 CH AM HANDHELD CB TRANSCEIVER. 78-785 represents state-of-the-art high-tech engineering. Designed for 40 channel Citizen ...
8 pages
Midland 75-785 Owner's Manual - ManualsLib
https://www.manualslib.com > ... > Radio
View and Download Midland 75-785 owner's manual online. ... DC 13.8V CHARGE 40 CHANNEL CB TRANSCEIVER 75-785 SQUELCH VOLUME DC 13.8V CHARGE page 4.
75822 HANDHELD CB TRANSCEIVER User Manual G-300 ...
https://fccid.io > Midland Radio Corporation > 75822
75822 HANDHELD CB TRANSCEIVER User Manual G-300 owners guide Midland Radio ... Owner's Manual Model Number 75-822 Features Include: 40 CB Channels 10 ...
USER MANUAL Midland 75-822 40-Channel 2-in-1 CB Radio
https://www.search-manual.com > midland-75-822-40-...
User manual, Midland 75-822 40-Channel 2-in-1 CB Radio, Midland, 75-822, 40-Channel, 2-in-1, CB, Radio, with, Weather, Alerts.
1helpful
Midland 75-822 schematic needed
There is...I found one in german, same radio but under the name of Alan-42. Easily translated using google. I was using a lobrary computer and was unable to print or save it, but it's ouut there.
2answers
Purchased a midland 75 785 from u s will it work on u k channels
  • For 11 meter (CB) the standard 40 channels will be the exactly same as the "EU" set of frequencies (channels). However the "UK" 11 meter (40 channels) and the U.S.A. 40 11 meter (40channels CB) will not work together at all. This includes any actual Citizen Band radio, excluding Export 10 an 12 meter radios often labeled as "CB'S" which they are not.
  • Hope this helps.
2answers
Midland 75 785 purchase from us will it work on uk channels
  • Hope this helps.
I have purchase a midland 75785 cb isit compatable with uk chanels
  • Hope this helps.
Hi i have a midland alan 78 plus multi and it will not receive or transmit ,when you press the ppt button there's no signal strength showing on the display , the power supply is good and worked fine last...
hello there your problem is simple the final transistors have blown as you have no audio an audio transistor is also required best leave it to the pros to repair goodluck
My alan 48 plus cb dont seem to change to uk how do u change this thanks
the first button on the right hand side changes the fm to am but these usually break down. it is a small push button switch with four legs two at each side, but recomend sending it in for repair.
My midland allen 78+ uk channel has changed to am it should be fm
I Italy 40 Ch AM/FM 4 Watts I2 Italy 34 Ch AM/FM 4 Watts D Germany 80 Ch FM 4Watts/ 12 Ch Am 1 Watt D2 Germany 40 Ch FM 4 Watts/ 12 Ch AM 1 Watt D3 Germany 80 Ch FM 4 Watts/ 40 Ch AM 1 Watt EU Europe 40 Ch FM 4 Watts / 40 Ch AM 1Watt EC CEPT 40 Ch FM 4 Watts E Spain 40 Ch AM/FM 4 Watts F France 40 Ch FM 4 Watts / 40 Ch AM 1 Watt UKE UK 40 Ch Fm 4 Watts UK frequencies UKC UK 40 Ch Fm 4 Watts CEPT frequencies PL Poland 40 Ch FM/AM 4 Watts midland alan 78 multi plus frequencies
Top Midland Radio Communications Experts
eradiostore
eradiostore
ZJ Limited
ZJ Limited
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
