Question about Amana 19.7 cu. ft. / 558 liter Upright Freezer Deepfreeze AFU2004AW
Can an 3.5 cu ft freezer be layed on its side for travel
  • 133 Answers
Yeh u can...coz company made it wid dis quality
Posted on Feb 26, 2010
Maytag upright freezer will not drain and water will freeze in bottom. How do you repair Model CFU2046ARW
Check your door/'s are sealing if they leak u will get freezing occurring in the bottom and around the door will have allot of condensation.
good luck all the best . P's always lay liquid bottle on their side as they will cool quicker and be better on electricity.
Apr 04, 2014 | Frigidaire 20.6 cu. ft. / 583 liter...
I have a Frigidaire upright freezer. I unplugged the freezer for approx. one month because I did not need it. After plugging back in, the compressor seemed to start ok. I left running overnight. the...
besides hitting the compressor with a hammer. unplug and lay on its side for 2 hours then upright for 24 hours plug back in. Never ever unplug a freezer
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Oct 04, 2017 | Frigidaire 12 cu. ft. / 340 liter Upright...
Layed down freezer to transport in car for long journey left 4 hrs before start up working fine freezing but side edge behind door seal feels quite hot since
this is normal until all the freon has had a chance to get recirculated throgh the system.
make sure the evaporator fan is also working in order to properly cool the freezer.
Oct 09, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Can i transport the freezer on its side for three hours so it fits under my tarp of pickup will it hurt it
as a general rule, no. Laying it on it's side can cause the oil in the compressor to flow into other parts of the systems so when you turn it on, it may damage the compressor. The general rule of thumb is, if you should do that, you should not run the unit for at least 24 hours. This should, but not for sure, allow the oil to flow back to the compressor. I've never heard anything good from anyone who's ever done this.
Sep 03, 2010 | Danby 4.7 cu. ft. / 133 liter Upright...
Handling and moving
Good day,
Should not be done. First off you should be sure it is performing properly both in temperature and cycling before accepting it.
Layed on it's side is a **** shoot. But if your stuck, drive only smooth roads slowly, and upon arrival carefully upright it and let it set 48 hours to allow the oil to return to the compressor.
If step one works out, renting a truck, if the distance is short, is best.
May 12, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
I moved my freezer and now will only stay cold for a short time, why?
You jard the liquids. Did you just move it a little or move like to another house because if you move a frig or freezer somewhere or lay on it's side you shouldn't plug in for an hour or more so it all settles or it won't work. Hope this helped
Apr 29, 2010 | Danby 5.5 cu. ft. / 156 liter Chest...
How to move a whirlpool freezer on its side
You can lay the freezer on its side to move. If it is on its side for over 30 Min's though you will need to stand it up for 24 hrs before you plug it back in to the power. You need to do this so the freon settles back to the compressor.
It is always best to move them standing up.
Apr 23, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Need to transport older Kenmore upright freeer
I would not lay it down but if you can get around it lay it down so the compressor is at the bottom. DO NOT TURN ON FOR 24 HOURS AFTER STANDING UP.
Apr 17, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
I want to cut the top 6 inches off my 50 year old chest freezer
Yes,there are lines and the coil within 6 inches of the top.
You could just lay it down on it's side.
Please rate this a fixya
Feb 03, 2009 | Woods 5.3 cu. ft. / 150 liter Chest...
Moving a freezer
Shouldn't be a problem in itself, but it's prudent to let the freezer stand the right way up for an hour or two before you turn it back on.
Nov 28, 2008 | Frigidaire 14 cu. ft. / 396 liter Upright...
Amana 19.7 cu. ft. / 558 liter Upright Freezer Deepfreeze AFU2004AW Logo
127 people viewed this question
Top Amana Freezers Experts
John Tripp
John Tripp
Dennis Boxerman
Gil Shultz
Are you an Amana Freezer Expert? Answer questions, earn points and help others
