You must make sure if this is supported by the phone- the MMS- and if the frequency is correct to the network youa re in.
Please consult once again with your network T mobile to confirm if this model works.
the @ is under symbols key in option (along w alot other symbols) ...make sure your mms settings are correct...when sending a regular text (if a picture is added the cell will promt you to switch to MMs mode
These phones comes with Chinese mms and sms settings only. You need to set it up yourself. if you want let me know what's your service provider, I have the info. about T-Mobile, but I guess we can get any other information from Google.
If you have a I9 you must go to this site. very helpful every question you have has been asked at this site. Regestration is free. http://www.i9forum.co.uk/
Most setups are listed directly on this site. I took this qute from someone asking the same question.
I didnt see the thread they were ytalking bout, but they are suggesting stting it up like the Nokia 2610. I would recommend posting this question again on the above site. Below is what I copied from there.
Hi I'm in Sydney and use Optus mms and wap with no problems. If you look in this thread under the topic Easy configure MMS. Follow the instructions to the Nokia site for the 2610 and you should get a text back to set up MMS and the internet. Good luck It worked fine for me.
hey you guys : ) i can the help to fix this problem i called t-mobile customer care and you have to ask for a tier 3 customer service rep and they send you three text messages that hook up internet and mms call em you will see : ) send me some love later !!!!!
***First Step***
1.Main menu --> Select Services
2.Select Data Account --> Select GPRS
3.Select the first entry
4.Edit the account name to whatever you would like
5.Edit APN to wap.cingular (lowercase)
6.Edit Username to [email protected] (UPPERCASE)
7.Edit Password to CINGULAR1 (UPPERCASE)
8.Edit Auth Type. to Secure
9. Save
Select Back --> Select Back
***Second Step***
Select WAP
1.Select Settings --> Edit Profile
2.Select the first entry --> Edit Profile
3.Edit the name to whatever you would like
4.Edit Homepage to http://device.home
5.Edit Data Account to the Name you established in the First Step
6.Edit Connection type to HTTP
7.The IP address is 066.209.011.032 and the port number is 8080
8.Edit Username to [email protected]
9.Edit Password to CINGULAR1
Select back or done
Select Activate Account
You should now see a Black [G] in the upper left of your screen.
To access the net select Services --> WAP --> Homepage.
If it connects the Black [G] should turn Green
MMS
Select Messages --> MMS --> Message Settings
Select Server Profile
Select Edit Profile
Edit Rename Profile to whatever name you would like
Edit Home Page to http://mmsc.cingular.com
Edit Data Account to the same data account you created for WAP
Edit Connection Type to HTTP the IP address is 066.209.011.032 and the port is 8080
Edit the Username to [email protected] (UPPERCASE)
Edit the Password to CINGULAR1 (UPPERCASE)
Select Done or Save
Make sure to activate the profile and you are good.
For all of you guys out there that need to setup your internet on the cect I9, using att service.
