You did not mention which input you attached the RCA cables to. If it was component it would be one selection, if it was composite it would be another. If you do not have your operations manual you can find the manual at http://www.retrevo.com/samples/RCA-TV-manuals.html Download it and starting on page 7 look at the diagrams they show for hooking up the DVD. Inspect your hookup and make sure it is correct. If it is then follow the procedure they give for selecting the device. Using this manual you should be able to sort out your problems. This unit has quite a few inputs but they all should be available on the menu. I suspect that you are looking at the wrong one. Get the manual and look at the pages that I mentioned. Let me know if you need anymore help.
hardrocko
Thanks for using FixYa
