Expert
- Posted on Feb 28, 2010
Re: there is power to the washer, water will drain
Try unplugging machine for 30 seconds then plug back in then lift and close the lid 5 times which will reset the motor. Try the spin cycle if it works you may have had a power surge which took the motor out and just needed reset. If it fails you may have a bad inline fuse or motor.
Did you check the Direct Drive coupling? Newer Whirlpools do not have a belt. They will pump but not spin.
