Will not power on. Check fuse. That's not it.
There's a Standby/On switch which is the one that the remote triggers.(There's a tact button on the set, too). BUT there's a master 'rocker type' switch that cuts mains power to the set. Make sure that this master switch is on before you use the remote's on/off switch. It's usually hidden behind the set at the bottom, out of obvious sight.
