1) Complete cleaning using copressed air or lint free cloth
2) check the cleaning blade on your drum (Round Glass cylinder)3) Change your drum unit
4) replace rollers
you need to print clean page two or three times to clean printer path for toner , then check the last page you if there other black market , tell me , what black market looks like , hope that helped you
There will be a flap at the back that drops out and down to give access to the fuser for clearing jams and "straight through" printing. Four lines repeating down the page is equally likely to be be a mark on the cartridge drum, possibly from the Primary Charge Roller if the unit has been very hot or not used for a period of time in higher temperatures. Remove the toner cartridge and in LOW light manually rotate the drum using the gear at one end of the cylinder. Look for a scuff mark right across the drum or a black/grey line. You may be able to clean the drum with a cotton ball and alcohol. Try the print again and see if there is any improvement. If you have another cartridge in hand you might try that to verify cartridge or fuser.
Does this line appear when you try to print to the machine? Or when you make copies on the scan bed? If so, then you most likely have a mark on the drum unit. If not, then the **** glass that the document feeder uses is located to the left of the large glass surface, attempt to clean that and ensure that no mark or scuff marks are on the **** glass.
