I had my LG KE970 connected to my computer to dowload some files.when I ejected it,I had wireless off displayed instead of the name of the network provider and of course no network available.
Menu-Settings-Reset The problem appears when the USB connection is set to MASS STORAGE instead of DATA SERVICE and the USB cable is disconected without SAFELY REMOVE action from the computer.Menu-Settings-Reset The problem appears when the USB connection is set to MASS STORAGE instead of DATA SERVICE and the USB cable is disconected without SAFELY REMOVE action from the computer.
You can't post conmments that contain an email address.
Turn on the console and navigate to the wireless settings screen. On
the Xbox, the menu path is "Settings -> Network Settings ->
Advanced -> Wireless -> Settings" On the Xbox 360, the menu path
is "System -> Network Settings -> Edit Settings."
Set the SSID (network name) on the Xbox to match that of the
wireless router. If your wireless router has enabled SSID broadcast, the
SSID name should appear pre-selected on the Xbox display. Otherwise,
select the "Specify Unlisted Network" option and enter the SSID there.
Specify "Infrastructure" as the Network Mode. (Infrastructure is the
mode used by wireless routers.)
Set the Security Type to match that of the wireless router. If your
router uses WPA encryption and the type of adapter connected to the Xbox
does not support WPA, you will need to change your router settings to
use WEP encryption instead.
Note that the standard Microsoft Xbox 360 Wireless Network Adapter
supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740)
only supports WEP.
Save your settings and verify the network is functional.
On the Xbox, the Wireless Status screen displays whether a
connection has successfully been made with the wireless router, and the
Connect Status screen displays whether a connection has successfully
been made through the Internet to Xbox Live.
On the Xbox 360, use the "Test Xbox Live Connection" option instead.
If you need more help post back!
Thumbs and testimonial are welcome!
To connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet port (sometimes also called a wireless network bridge) must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead.
Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.
On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.
Tips:
Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
only supports WEP.
Hi, PC Suit for LG Shine KE970 mobile you can download here-http://www.lg.com/uk/support/mc-support/mobile-phone-support.jsp 1. Download the LG PC Suit. 2. Double click the exe file to run it. 3. Follow the instructions given to you. 5. When installation has completed, the program will open and you can connect your LG Shine KE970 mobile without any problem.
If your KE970 has the same OS as my wife's KF750, go to 'Menu > Settings > Connectivity > USB connection mode'. Yours must be set to 'Music sync'. Try to set it to 'Data service', instead.
Tips:
you need to have her phone reflashed to orginal status - not sure where he got it, but in europe bluetooth takeover programs are highly available to hackers.
it can be used in a malicious manner - and illegal
go to settings and then to filight mode. see if the flight mode is turned on. mine wasn't, but I still had the "wireless off" written on the screen. I turned it on and off again, and the network appeard. hope this will help you.
