Question about Panasonic TX-32LX60 32 in. LCD Television
TX-32LX60FA we receive 1 sec visual and after that only sound and then the screen stays black
    New Friend:
  • 14 Answers
Check the Inverter Board or replaced it.
Posted on Jul 21, 2010
6ya staff
SOURCE:
The question on the hp g42 the f12 lightOrangestay's on And the cap key blinks 1 x every 3 sec.
could be faulty ram or screen faulty,or even over heating,clean out the fan.
Feb 20, 2015 | HP Computers & Internet
Onkyo TX-DS676 Receiver
check that you have selected that option on both player and receiver.
optical setting. a lot of systems are defaulted to hdmi
Apr 12, 2014 | Onkyo TX-DS676 Receiver
Panasonic TX-L42E5B tv sound working but screen is black
It can also be the YMain board or the back light inverter board or a capacitor or fuse has blown on the power supply board. Which you usually lose sound before you lose both sound and picture. Try to hard reset is for about 4-6 hours by completely unplugging it.
Mar 25, 2014 | Panasonic VIERA TX-L42E5B 42" LED TV...
Receiver turns off
1) Return it.
2) It sounds like you have shorted the speaker wires. Redo the wiring ... and pay attention to your owners manual this time.
Jan 07, 2014 | Onkyo TX-SR503 Receiver
HDMI signal cuts out for a few seconds constantly from receiver to television. It does it when switched to cable box and the roku box. Onkyo TX-SR606 Scientific Atlanta Cable box thru HDMI Roku Box...
Mine did the same thing where the screen would go black for a few seconds and then the picture and sound came back. I would try (1) switch HDMI cables, (2) try a different HDMI input in the back of the receiver, (3) try different input in the back of the TV. None of these seemed to work with mine. I finally ended up running the cable box direct to the TV and only run the audio through the reciever via coax or digital. No more problems. I think the HDMI inputs in the back of the reciever have a problem continuously carrying the signal if it is the leaset bit weak.
Sep 08, 2010 | Onkyo TX-SR606 Receiver
Onkyo TX-DS696. No right channel speaker sound
hello there 2 transistor 1 for the right channel and 1 for the left first thing 2 do is a visual check in good light check for any burn't part or any bulging capacitors if everythink looks ok then check underneath the board for dry joints if then you will need a mulitmeter to start testing components
regards
shasun
May 15, 2010 | Onkyo TX-DS696 Receiver
Please send me Canon Ir all model Error code. How can solve it?
Error codes for iR2016i,2020i for other machines codes you need to get the specific manual, these manuals can be downloaded from Ebay, look for user ID ultimate_sacrifice A seller on Ebay.
No. Tx/Rx Description
##0100 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0101 [Tx/Rx] the modem speed does not match that of the other party.
##0102 [Tx] at time of transmission, fall-back cannot be used.
##0103 [Rx] at time of reception, EOL cannot be detected for 5 sec (15 sec if CBT).
##0104 [Tx] at time of transmission, RTN or PIN is received.
##0106 [Rx] at time of reception, the procedural signal is received for 6 sec while in wait for the
signal.
##0107 [Rx] at time of reception, the transmitting party cannot use fall-back.
##0109 [Tx] at time of transmission, a signal other than DIS, DTC, FTT, CFR, or CRP is
received, and the procedural signal has been sent more than specified.
##0111 [Tx/Rx] memory error has occurred.
##0114 [Rx] at time of reception, RTN is transmitted.
##0200 [Rx] at time of reception, no image carrier is detected for 5 sec.
##0201 [Tx/Rx] DCN is received outside the normal parity procedure.
##0220 [Tx/Rx] system error (main program out of control) has occurred.
##0232 [Tx] encoding error has occurred.
##0237 [Rx] decoding error has occurred.
##0261 [Tx/Rx] system error has occurred.
##0280 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0281 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0282 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0283 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0284 [Tx] at time of transmission, DCN is received after transmission of TCF.
##0285 [Tx] at time of transmission, DCN is received after transmission of EOP.
##0286 [Tx] at time of transmission, DCN is received after transmission of EOM.
##0287 [Tx] at time of transmission DCN is received after transmission of MPS.
##0288 [Tx] after transmission of EOP, a signal other than PIN, PIP, MCF, RTP, or RTN has
been received.
##0289 [Tx] after transmission of EOM, a signal other than PIN, PIP, MCF, RTP, or RTN has
been received.
##0290 [Tx] after transmission of MPS, a signal other than PIN, PIP, MCF, RTP, or RTN has
been received.
##0670 [Tx] at time of V.8 late start, the V.8 ability of DIS front the receiving party is expected
to be detected, and the CI signal is expected to be transmitted in response; however,
the procedure fails to advance, and the line is released because of T1 time-out.
##0671 [Rx] at time of V.8 arrival, procedure fails to move to phase 2 after detection of CM
signal from caller, causing T1 time-out and releasing line
##0672 [Tx] at time of V.34 transmission, a shift in procedure from phase 2 to phase 3 and
thereafter stops, causing the machine to release the line and suffer T1 timeout.
Dec 12, 2009 | Office Equipment & Supplies
Onkyo TX-SR606 Reciever - 20 sec after power on, screen is green
The HDMI version in your receiver is 1.1 or 1.2 which will not pass video as it should. It's not Onkyo's firmware at issue, it's HDMI and in all receivers up to 2008 model year this is a very heated problem! The only fix is to run FIOS directly to the TV via HDMI and run it's audio to your receiver with Digital Coaxial or Optical. Hope this helps
Jun 11, 2009 | Onkyo TX-SR605 Receiver
Onkyo receiver playing in mono only
sounds like a reception problem. Is there a visual meter for the reception? Check your antenna.
Feb 02, 2007 | Onkyo TX-8210 Receiver
Panasonic TX-32LX60 32 in. LCD Television Logo
124 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
