Question about Gestetner DSm515pfd Digital Copier - Printer - Scanner - Fax
Gestetner-2412Z copier-error code UF
Gestetner Destktop 2412Z Copier displaying error code: UF. What does it mean and how to resolve or clear it? The copier can initialize when I turn on the popwer but cannot copy due to error. I carried out simulation 02 and I was able to print several copies but when I lleave simulation. UF displays again. I'd checked the developer powder and found out that it's running out. Does it have something to do with the error? I'll appreciate any help or assistance you will extend to me.
Can I get the gestetner driver for photocpier.
Posted on Jan 28, 2009
My gestetner DSM 618 is showing error code SC ERROR OCCURED 542
Posted on Oct 10, 2008
    Problem Solver:
  • 8 Answers
UF is a panasonic code,the u means user fix.If you have an users guide it will tell u what to do.
Posted on Mar 04, 2008
  • Anonymous Mar 04, 2008
    UF code is a user fix,look in the trouble shooting section of your user manual.Posible causes,open door,toner colection bottle full,and of course out of toner.
6ya staff
SOURCE:
CODE SC542
press clear mode key follow by 107 and hold the stop/clear key to enter sp mode power the copier off and on if the problem reoccur replace fuser unit and enter mode and off and on the copier
May 11, 2013 | Gestetner 3255 3265 3270 3355 3370 5502...
Functional Problem within copier, code SC545
The error code 545 or SC545 means that the fuser, also known as the fixer assembly has a thermistor problem (this part melts the toner onto the page). It could also mean that the fusing lamp is disconnected.
If a simple reset of the of the error code does not work ("Clear Mode"+107+"Clear/Stop" hold for 5s. Turn ON and OFF the Main Switch) you may need to have your machine serviced by a professional. It is your best bet to also have standard cleaning maintenance done by your on site technician after fixing the error.
Jan 14, 2012 | Gestetner DSm735 Black and White Copier
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
My mita DC-1560 copier screen displays UF, what is the meaning of the code UF, and how do I solve it
UF means that the dev unit connector is removed or insert the toner container further inside
Aug 06, 2010 | Kyocera KM-1505 Copier
We have a gestetner DSm622sp we are getting an error code SC320.
Hello sir; the error code you have display, that's means laser motor don't work, replace it!
May 18, 2009 | Gestetner DSm515pfd Digital Copier -...
ERROR UF-
I can help you, but what kind of copier is it? What make and model?
Mar 02, 2008 | Office Equipment & Supplies
The large tray on the right is where the jam is. Slide the lever to the right and disconnect it from the machine. Open the cover as if you where filling it with paper. Look inside for and half sheets of paper, or possibly misloaded paper. If everything is ok, the front cover by the lever needs to come off. There are 2 screws on the bottom of the cover. Take the cover off, and then take the upper cover off. Underneath it is a switch. See if there is a piece of paper wedged in it. If so, remove it. Replace covers. If that does not solve the problem, then it probably needs feed rollers. You might be able to clean them with soap and water, but it will jam again in time.
Mar 01, 2008 | Ricoh Aficio 450 Copier
UF Error code-Gestetner 2412Z
You may find it easier to solve the problem by asking the same question under its original manufacturer model........Mita DC1257
Good luck
Error Code: UF
failure of data transfer between boards.-or defective of backup battery.cofirm good connector pluging and good soldering points in boads.
Feb 29, 2008 | Office Equipment & Supplies
Gestetner DSm515pfd Digital Copier - Printer - Scanner - Fax Logo
376 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Bernard D'Souza
gggg
Adorjani Laszlo
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
