If you know how to use a multi-meter you will need to do the following:
Will need to disassemble upper console to 1.Check ribbon connection and continuity from upper to lower board 2. Check continuity of safety key switch 3. check dc voltage from lower to upper boards.
If ribbon is defective replace it.
If safety switch is defective replace it.
If lower board is defective get pricing for component
If upper board is defective get pricing for component
go to icofitness.com
