Televison & Video Logo
Posted on Feb 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't get rid of the closed cation on my lg tv
I can't get rid of the closed caption on my lg tv model 42LH41
sorry....the type keeps on showing up on the screen as they are speaking
Henry Thomas
Level 3:
Genius:
  • Master 1,074 Answers
  • Posted on Feb 28, 2010
Henry  Thomas
Master
Level 3:
Genius:
Answers
1074
Questions
Helped
336415
Points
2402
Take out the eprom ic and the tv will reset.the eprom is a 4 leg ic at the front of the tv board close to the micro if you cant do it your self take it to a tech.good luck.
How do I change screen size to read closed captioning?
you should have a button on your remote that says something like: aspect, pix size, screen size...etc
How do you remove closed captioning? I have a 4yr old 50" plasma tv. Today the captioning just popped up and I can't figure out how to get rid of it
Hi
1* Use the CAPTION button repeatedly to select Caption Off, EZ Mute, or On.
* EZ Mute shows the selected captions option (if available on program) when the TV sound is muted.
2* Press the ENTER button to save.
Caption Tips
* Not all TV broadcasts include closed caption signals.
* Sometimes TV stations broadcast four different caption signals
on the same channel. By selecting CC 1 to CC 2, you
can choose which signal you view. CC 1 is usually the signal
with the captions, while Another mode might show demonstration
or programming information.
* Your TV might not receive caption signals normally in the following
situations.
OK.
How do I enable closed captioning on my Zenith PIP System 3? Thanks.
Hello
To enable close cationing on your TV follow this:-
[1] Press "Menu" button on the remote control to appear "Setup" menu on the screen.
[2] Use "Up and Down" arrows on the remote contol to select "Captions/Text" on your screen.
[3] Press "Right or Left " arrows to select any one of the following options. Caption-1, Caption-2, Caption-3, Caption-4 Text-1, Text-2, Text-3, Text-4.
[4] Press enter to return TV viewing.
To turn the caption feature to "On" or "Off'
[1] Press menu key on the remote control to display "Setup" menu.
[2] Using "UP/DOWN" buttons to select captions on your screen.
[3] Press "Right or Left" arrow to switch the captions feature 'ON" or "OFF" or "EZ Mute"
[4] Press enter to continue.
Ok.
Why does close-caption appear on screen eac time I turn it on.
On your remote control find the CCD button and press it until you find the option to turn off the closed caption or select the closed caption option to use only when the sound is muted. If this does not eliminate the problem, you may have a switching problem in the control panel.Try turning off your television for a period of time and then turn it on and try resetting the control. If this fails you may want to contact customer service for technical help at 1-877-467-4289. Hope this helps you with your problem.
Projection TV
You will probably find the captioning is turned on in the cable box and that's why you haven't been able to get rid of it through the TV. The box remote control should allow you to access the setup menu so you can turn off the captioning. Your cable company should be able to help you if it's not clear from the on-screen information.
3helpful
2answers
How to remove closed caption from JVC TV without original remote
how can i get rid of the closed caption on my magnavox tv without the original remote
Cationing ws working, but isn't now. LG TV.
if you are watching satellite or cable, make sure that captioning is on on that device also
Cannot get rid of captions on TV screen
Have you gone into the menu and located Closed Caption or just caption and turned it off? It might be under the Audio menu or Features.
Need to get rid of closed caption
If you have original remote for t.v. , hit the button under the sleep timer button on remote, and eventually the closed cation words will be removed from the bottom right corner of t.v. Hope this helps , good luck .....
Closed captions will not disappear
Some TV will not display close caption in HD mode. This is why its Grey out in HD mode. If you switch to regular input, i can bet you your close caption will not be Grey out. The problem you are having is your cable box has close caption enable. You must go into the cable box menu and turn caption off. In some box you may have to call your cable provide for assistant.
Best regards
Circuitcity
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
