Kenmore 22422 Top Load Washer Logo
Posted on Mar 03, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Servis washing machine
Not spining the carbun brushis look ok. It washis ok just the motor not going to spin speed ?
Its Servis A Ecocare 1000
  • Anonymous Mar 13, 2008
    won't spin
john mc donald
Level 2:
  • Expert 121 Answers
  • Posted on Mar 03, 2008
john mc donald
Expert
Level 2:
Answers
121
Questions
0
Helped
74710
Points
213
The bushes might look ok but they only last a year and a half tops thats wat it sounds like to me if it cant spin right
My Servis M3001 washing machine will not fast spin , it will spin and the belt seems to be ok , the machine is filling and draining ok , can you help at allThank you
Some times on front loaders if it is out of balance it will not go into fast spin. Try to remove some of the cloths and see if this helps.
Best of luck
'RR
2answers
Servis 7kg 1500 AA - bush's and motor, ok and
relay is stacked so you start the machine off position power on the wash butten you will check this method
What holes
Open the drawer at the top left of the front of your machine: you will see 3 compartments: right is prewash, middle is for softener, left is for wash. WATCH OUT- these machines do not need as much washing powder as the american models-putting too much soap could damage your machine and lenghthen the cycles.... I use half of what I used in my previous american washer.... do not be surprised either by the spinning cycle: before going full blown into spinning the machine has sensors that perit autobalancing of the laundry. You must not load laundry above 3/4 of the diameter of the drum.
Servis ecocare 1000, spinning to fast on aggitate,
It sounds like the speed control is acting up that controls the speed of the motor..
This is usually built into the main control board, and means replacing the unit. the only other possibility , is if the motor has a thing called the tacho magnet,this is to be found on the end of the motor away from the drive pully.
What you are looking for is a round magnet about 20mm in diameter, if there is one, check to see if it is loose or broken as this can effect the speed of the motor.
Plz rate my solution.
Thanks.
2helpful
My servis washing machine turns and empties but wont spin machine isnt spinning
I suggest you remove motor and check the carbon brushes fitted at the end of the motor, if they are less than 2-3mm long ,they need replacing.
Thanks.
Servis easy logic 1600 wont spin
servis easy logic 1600 wont spin just moves the drum half a turn and stops but repeats all the time
Servis m6160w logic 1600 tripping rcd
many servis have an induction motor but later models have a brush motor.
worn brushes will not cause an earth fault. suspect part of the motor windings are down to earth. also possible you have a leak in the tub or door gasket so that on spin, water is thrown onto an electrical item
3answers
Have a Servis 1500 Easilogic washing machine. Decided last night that it won't do the spin cycle. Any ideas? Many thanks! Peter.
i used to deliver servis machines and exchange faulty ones, the most common problem was the regulator (the wash selection dial) they are not very sturdy and frequently break down. have you tried just a spin, without a wash.
8helpful
2answers
Servis easi logic 1600 washing machine not working
my servis eai logic 1300 will not rotate half way through the wash but will still spin and dry etc please advise.
Servis 1100 washer
Maybe you are overloading this weak useless machine. (I have the same)- Try washing one sock at a time
Alexander
vince
