Question about Microsoft Windows XP Home Edition
The SMTP server returned an error. Account: 'pop.012.net.il', Server: 'smp.012.net.il', Protocol: SMTP, Server Response: '-ERR Permission Denied', Port: 25, Secure(SSL): No, Error Number: 0x800CCC60
    Brigadier General:
  • 10,406 Answers
Most SMTP-servers will give "permission" to be used only when your computer is connected via an IP-address assigned to you (statically or dynamically) by the Internet Service Provider.
So, if you are using wireless Internet access, maybe provided at some retail location, rather than connected by Ethernet cable to '012.NET.IL', or wirelessly within your own home, using your own wireless router, you will get this error-message, when you try to "send" E-mail.
Posted on Feb 28, 2010
6ya staff
SOURCE:
The message could not be sent because the server rejected the sender's e-mail address. The sender's e-mail address was 'fkb@ameritech.net'. Subject '', Account: 'pop.attyahoo.com', Server:...
One problem is that the incoming (POP) mail server shown in the error message appears to be incorrect. The server address should be "pop.att.yahoo.com" (with a period between "att" and "yahoo"). The incorrect mail server address may interfere with authentication of the sender's email address, which is needed before the outgoing message is sent.
The "530 authentication" message indicates your outgoing (SMTP) server likely requires "server authentication". Also, the "Port 25" message indicates your email program is currently trying to send via Port 25, with no SSL; but Ameritech/Yahoo accounts appears to use Port 465 with SSL enabled.
See more on sever settings for "ameritech.net" users:
http://www.dslreports.com/faq/5535
https://motorola-global-portal.custhelp.com/app/answers/detail/a_id/61941/~/i886---at%26t,-bellsouth,-sbcglobal,-ameritech-email-settings
I would suggest you check the settings for your Ameritech email account in your email program. You may need to correct several settings. The steps to access account settings are somewhat different for various email programs (Outlook, Windows Live Mail, Thunderbird, etc.). You should be able to find guidance in the "help" section of your email program.
Feb 05, 2011 | Outdoor Concepts OCI AD20 27 Stainless...
I have yahoo id i wand configure to my outlook express i am getting this error There was a problem logging onto your mail server. Your Password was rejected. Account: 'pop.mail.yahoo.com', Server:...
There was a problem logging onto your mail server. Your Password was rejected. Account: 'pop.mail.yahoo.com', Server: 'pop.mail.yahoo.com', Protocol: POP3, Server Response: '-ERR [SYS/PERM] pop not allowed for user.', Port: 995, Secure(SSL): Yes, Server Error: 0x800CCC90, Error Number: 0x800CCC92
make sure your password is correct because this error description states that your password is incorrect
Jul 08, 2009 | Microsoft Outlook Express
The message could not be sent because one of the recipients was rejected by the server. The rejected e-mail address was 'a.tia62@yahoo.com'. Subject 'testing', Account: 'mail.eastern.com.ph', Server:...
Greetings,
this is a server rejected recipient error message for Outlook/ outlook express. mainly if this is a correct email address that you were trying to send the email on then you need to check for the configuration settings for Outlook express.
Goto Outlook express- higlight mail tab- select the user a/c- click properties on right- goto server tab check that server is
incoming: pop3.eastern.com.ph
outgoing: smtp.eastern.com.ph
click save
Regards,
TechSup1
May 01, 2009 | Computers & Internet
Message could not be sent. Server rejected sender's email address
the message could not be sent because it rejected as the sender
Jan 15, 2009 | Computers & Internet
The issue is: Unable to Send/Receive emails from winThe host 'POP3' could not be found. Please verify that you have entered the server name correctly. Account: 'POP3', Server: 'POP3', Protocol: POP3, Port:...
You are receiving this error because of one of two reasons:
1) Your email account is not set up properly. Click on Microsoft Outlook, click on Tools, then Accounts. You will see a window with columns stating Account-Type-Connection. If an account is set up then click on it then click on Properties. Click server tab and you will see the SMTP server block and the POP3 server block. Both of these fields will read as follows: pop.XXXXX.net and smtp.XXXXX.net. Your Internet Service Providers name will be in the XXXX. If these are not set up properly then you cannot connect to send email. If they are filled out correctly then you need to call your Internet Service Provider and inform them of your situation. Their server is not working properly.
Don't forget to 4 star this solution.
Microsoft Windows XP Home Edition Logo
544 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
ThaMp3Doctor
ThaMp3Doctor
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
