How do i set the date and time on this calculator.
User guide is here ...
http://safemanuals.com/user-guide-instructions-owner-manual/SHARP/EL-1801PIII-_E
Instructions are halfway down column 1.
Basically, you use the reset button on the back, then enter the relevant fields, delimiting as with a period <.>
I think their illustration explains it better than I can in words!
SOURCE: How do I set the date on Sharp EL-1801Piii
Adjusting the tiome is just like adjusting the date, owith the only difference that you just enter two values (hours and minutes):
1. Move the Grand Total/ Rate Setting mode selector to the "Rate Set" "position
2. Enter the time in the orde of hour, minutes (use a point to separate the two values) and then presse the [Clock/Calendar] button to complete the entry.
You may also want to download the SHARP EL-1801PIII OPERATION MANUAL
SOURCE: To change the Date and
GRAND TOTAL / RATE SETTING MODE SELECTOR:
"GT": Grand Total
"•": Neutral
"RATE SET": To set the date, time, and tax rate, set this switch at the "RATE SET" position.
Date:
• Enter in the order of month, day and year, then press to complete the entry.
• Use to separate month, day, and year.
• When is pressed, the number entered is evaluated and displayed as "date" if the
value is within the following range; "Error" is displayed otherwise, and the previously set
date is restored.
Month: 1 - 12; day: 1 - 31; Year: 2000 - 2099 (in 4 digits) or 00 - 99 (in 2 digits)
Time:
• Enter in the order of hour, minutes, then press to complete the entry.
(There is no entry available for the seconds value. The clock starts at zero second.)
• If the hour/minute digit is less than 10, it is not necessary to enter the first digit "0".
• Use to separate hour and minute values.
• When is pressed, the number entered is evaluated and displayed as "time" if the
time is restored.
Hour: 0 - 23 (24-hour system for the hour entry), Minute: 0 - 59
