Hobart A200 Stand Mixer Logo
Posted on Feb 28, 2010
I want to know about changing the transmission fluid, what type, how much does it take, where is the drain, how do you fill it and how often should it be changed?
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Mar 02, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
1952
Points
8
Here is where you can buy the grease
http://www.food-equipment.com/Hobart%20gear%20case%20grease.htm
There is no drain cause it's grease that is used. It needs to be removed manually and the 3 shafts need to be pulled to get all the grease out. If you are not mechaniclly minded best taking to a professional.
1helpful
My minuteman concrete mixer leaking a lot oil from gear box bought oil seal , but i need to fill it back on what oil should i use and how much ? please advice .thank you . jerry
Not all oils mix well so completely draining the old oil before refilling is important except where you know what oil is already inside, which I note you don't.
You might find an application for your mixer in one of the online application catalogues - just choose your favourite brand. Most oil brands also have a technical department designed to make such recommendations.
If you can't find a recommendation then what you fill it with is very much your choice - many of the traditional oils for slow rotating gears and bearings have disappeared from the marketplace; the very sticky heavy oils and semi-greases have all but disappeared, some of which were blended with bitumen and some of which had to be warmed in order to make them flow enough to pour.
You could equally choose an SAE 90 or 140 EP (extreme pressure) or even one of the modern semi-synthetic multigrade gear oils such as the SX 75-90 or you could go to the extreme and just use one of the many automatic transmission/power steering fluids that have superior lubrication and cooling properties.
It would be sensible to use an oil that is readily available and there is no reason why you shouldn't use a reasonable quality engine oil as most give a good performance in a gearbox and many vehicle gearboxes have specified engine oil...
Nov 29, 2020 • Food Mixers
Where do I drain the oil in a 60qt. thunderbird mixer
If you are referring to the transmission, I believe it's a sealed unit.
  • 3-Speed gear box
  • Transmission: Wide-faced, hardened alloy steel, helical gears fully sealed in transmission lubricant with heavy-duty ball bearings and clutch combine for highly dependable, quiet operation.
  • 2helpful
    Hello, my Hobart AE200 seeps oil from the front panel. How do I top it up? How often does the oil need replacing and with what type of oil? Thanks
    It's not oil in the A200, it's #2 weight grease. Although when it gets old enough it can break down far enough to basically become oil (either that or someone put oil in it previously). There are a number of answers written on fixya.com explaining how to disassemble the transmission and change the grease. Fill with 36 ounces #2 grease. FYI : disassembling the transmission and changing the grease is a very messy task and one can VERY easily reassemble the transmission incorrectly, so consider bringing the mixer to Hobart to have the job done.
    5helpful
    PLEASE HOW TO CHANGE OIL OF A HOBART MIXER H-600 C Cooper Lebanon PA
    underneath trans. you will find a drain plug remove, drain oil,replace plug ck the sight glass @ this time if not clear would recommend replacing glass remove top cover where the front cover screw theaded into remove that is your fill hole. add new oil till you hit level line in sight glass,reassemble
    12helpful
    Howdy, We have a Hobart H600 mixer and it looks like it needs oil. Where do I add the oil and what type should be used? Wesley McMenamins Pubs & Breweries
    take off top cover, where the front screw on top cover threaded into is the fill plug for the trans.drain oil replace drain plug , also ck. sight glass if dark or cloudy replace,@this time.trans. oil can be bought @ any hobartoffice the part# for the trans. oil is102973-66 that will come in a 128 oz bottle you will not need all of it. pour a little @ a time till oil hits line on sight glass. please vote thanks
    3helpful
    How do you change the oil in a hobart h 600-dt dough mixer & what type of oil do you use ?
    there is an oil case drain pulg under the top by the clutch, you can drain the motor housing through there, \
    i have used 5w30 in a pinch
    but it would be better if you ordered hobart oil from the website
    its cheap but very very good
    2helpful
    Oil leak from planetary
    The transmission center shaft seal/chimney is bad.You need to tear the transmission down in order to repair,let me know.
    Looking for location of drain plug for m802
    Look behind where the dough hook is near the pedestal,its a three quarter inch bolt.
    4helpful
    Hobart 140 Qt Mixer 4 speed. needs the oil changed? what kind of oil to use?
    You can use a heavy weight gear oil or call the local hobart branch for it.To remove oil----Look under the mixer where the beater shaft is in the back and you will see a three quarter inch nut,remove this nut and drain the oil then put nut back in.To fill the unit remove the top cover screws and remove the top,you will see a long hexagon nut in length,remove this and grab a funnel then add the oil---be patient it takes time to fill as the oil is heavy.
    3helpful
    2answers
    Transmission Grease for A120 and D300
    Thanks,, great info..
    I took mine all apart and the oil was just at the point of turning into grease. Nasty,, brown smelling ****.... I cleaned it all up and just used a sync 50w gear oil.. I over filled it and the extra ran out of the motor end of the gear box... It might have been about 2 table spoons too much.. Now it does not leak anymore.
    Thanks again,, jaybeesee
    Daniel from Penokee
    Top Hobart Food Mixers Experts
    vince
    NOEL
    NOEL
    Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
