Error 90 is a common fault code in domestics within the Electrolux, Zanussi, AEG range. It's a wiring fault /connection normally between the printed cicuit board and wires. switch off power, remove lid, pull off each connector on board checking for clip holding the connector in place, one at a time, look for arcing marks, rub pins gently with clean cloth, tensinsion up clips in connector(delicately) and refit. having done this, test again with a wet load on spin, then a wash programme. Before dispairing check the motor coonnections.
SOURCE: Electrolux 1087 E90
I found out the hard way that it's because the drain is blocked. Check the filter and even get a torch to look to make sure there is no coin or piece of wire jamming the pump.
