Hi, please ignore the above for it has no relation to your question. The Daytona does not have a date window so would not have a magnification window. If your Daytona has anything engraved on the rear of it, its highly likely to be fake, as Rolex did not engrave the rear of their watches.
The second hand on your watch should be the small sub dial at the 6 o'clock position, this moves round continuously. The large second hand should also move round the face once the top pusher is pushed, pushing it again will stop it. Pressing the bottom pusher will reset all the needles back to 12, except the 6 o'clock dial, as this is seconds.
If you remove the bracelet from the watch, you should have a series of numbers in between the lugs of the watch, where the strap would of been (before you removed it)
At the top, (12 o'clock position) it will have the model reference number. For instance ROLEX DESIGN 116509
On the other side, at 6 o'clock, it will have a serial number, for instance F520773. The F number is what dates the watch.. F is 2005.
If you wish to email me the numbers on your Rolex, I will check it for you, free of charge. Email is
[email protected]
If you have opened the watch, you should also have the watches model reference i.e 116509 stamped into the case back.
I can arrange repair for this watch, whatever movement it has inside.
Website is luxury sauce dot com, you can contact me via the website.
