HP PL5060N 50 in. Plasma HDTV Logo
Posted on Mar 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Thick Vertical Line
I have a really thick vertical black line going down the middle of my screen. What can I do to fix this? It takes up about half of the screen.
Henry Thomas
Level 3:
Genius:
  • Master 1,074 Answers
  • Posted on Mar 01, 2010
Henry  Thomas
Master
Level 3:
Genius:
Answers
1074
Questions
Helped
336406
Points
2402
The power supply is defected a capacitor filter is leaking.have a tech repair your tv.good luck.
2answers
Why is there a thick black vertical line in the middle of the screen?
The reason for the thick black line is that the screen is receiving no information to that section, either because the screen itself has developed a fault or the processor is not supplying to that portion, either way Im sorry to say the item is more than likley a uneconomical repair.
1helpful
How to i fix my Samsung Plasma TV which has a 3" wide black vertical bar down the middle?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
1helpful
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Toshiba 32sl410u have 2 vertical lines on screen
Likely a shop repair but:
Either a bad board (main, or power or even a inverter board)
Worst case if Black line and thick would be the panel (screen unit) which would be fatal but is not likely if lines not black.
6helpful
2answers
Tv is about 4 years old. Suddenly developed two
Your plasma screen is made up of 1080 verticle lines and now a few of these lines are not working. This is the screen itself and needs replacing.
10helpful
2answers
Mines a LG RZ42PX11 it intermittently gets a black vertical line down the middle of the screen.
Hi I have a LG RZ42px11 there are 6 vertical thick black lines running down the middle off the screen, when cold the TV seems OK but if it has been on for around 10mins or on standby the lines stay on screen.
Thanks.
Douglas.
2helpful
2answers
Can only see half the picture
Locate Vertical Output device--replace w/OEM equiv.or better.
Top HP Televison & Video Experts
 Mikey
Mikey
Stan Ford
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
