F12 SPECIFIC FOR LVB2000 INDESIT EVOLUTION / DIALOGIC. F12: Lack of Display card-Main Card Communication
1. Check the effectiveness of contacts on CNC Connector Card
2. Overhaul 8-way connector on Display card
3. Check continuity of CNC-CN 8 way connector
4. Replace Main Card
5. Replace Display Card
It stops spinning because the load is unbalanced. It will cycle over and over until the load is even then it will kick into a faster spin. Unbalanced loads could be due to too many items in the washer of a stabilizer problem in the hardware of the machine,
Sounds like the pulley that the drum belt rides on has loosened. You need to open up machine, find drum belt pulley, pull pulley taught, and tighten screws on pulley. Usually very easy to access that pully once covers are off
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
F12 is a Module connection fault, the link between the
modules is not holding, check the connecting plugs and associated wiring. For
more Hotpoint, Creda and Indesit error code solutions visit www.selfix-uk.co.uk
from the looks of it, this is called an f12
lights 1&2, communication error which seems to be quite common. I've got the same problem. If there's nothing in your filter, it could be the pcb (apparently, according to the research I've done so far). Quite expensive apparently (£200?), but these machines don't seem very reliable, lots of people on the web having problems.
