Question about Olevia LT23HVX 23 in. LCD Television
Olevia won't turn on.
I own a LT23HVX Olevia that turns on the little red light but when you push the power button the light disapears but the set dosen't turn on I tried the usb cord trick dosen't work and then I replaced the 2 1000uf 16v capacitor's on the power supply board can I try changing any other capacitors or all. Sugestion's needed please. Thanks ahead of time you guys.
  • 4 more comments
  • Anonymous Mar 12, 2008
    I have the Olevia LT23HVX and have the same problem.
    I couln't find any info on the USB Port on the Olevio site or manual other then where it is located.
    What type adapter connector does it take to plug the USB Charger into the TV?
    Thanks
  • Anonymous May 24, 2008
    We have a Olevia TV and the blue light is on--when we puch the power button on the screen just comes up with the word Olevia and nothing else
    Have tried everything we can think of but T V will not turn on
  • cephie Jun 15, 2008
    No sound or picture...the red power light is on, but TV won't turn on with the remote or the button on the set. I tried unplugging and plugging it back in, but it didn't work. For the last few weeks, it has usually taken a couple of tries to get it on, but now it won't come on at all.
  • tjharris Sep 12, 2008
    Me too... power-up gives just the blank Olevia screen...
  • Anonymous Oct 26, 2008
    Set stopped working at 13 months....Factory willing to do a flat rate repair if I pay 100.00 plus shipping. Guarantee for 60 days.
    One would think for a PAID repair, and the inconvenience of the failure, they could give a 2 year warranty on the entire product.
    Magnavox impressed me with customer service on a monitor, by helpting me figure out the problem, and VOLUNTEERING that it was under warranty... I did not know it was when I called.
    Olevia was lousy on the phone.....another case of a company cheazintg it up, to favor the big box stores profitability, at the public expense.
  • Anonymous Jan 29, 2009
    the usb quickfix worked for awhile, but now the darn thing won't turn on at all. it sounds like it wants to turn on, but it's not getting enough power. i'm out of ideas.
  • 3 Answers
I posted photos and a description of my solution for this problem here: http://www.flickr.com/photos/geegee123/sets/72157607269121264/ There's another thread on FixYa dealing with this same issue that has a variety of solutions as well.
Posted on Sep 14, 2008
I had the same thing happen today. I plugged the USB port into my laptop. Then al of a sudden everything came back to life. I then reconnected the VGA and was able to use the monitor again. Very odd, but I'm glad it works (for now).
Posted on Oct 20, 2008
    Problem Solver:
  • 9 Answers
Had same problem with same tv took it apart and replaced 2 of the 16v 1000uf and the 35v 680uf capasiters on the power supply board works fine now parts about $15.00
Posted on Nov 26, 2009
  • 42 Answers
Go with the power supply fix IT IS NOT A USB problem
Thanks for your in depth procedure with the pix
One thing when taking off the caps it is easier to use solder wick to remove the solder
By not heating up the land properly you can pull up the land and create a problem for yourself
Posted on Oct 02, 2008
Had the same problem and i think it just needs a little jolt of electricity to get it back working got a mini usb and touched the service port it sparked, screen turned white and then tv turned on try this and see if its helpful it just started working again i dont know if its a quick fix or permanent solution
Posted on Sep 26, 2008
Thanks
Posted on Mar 12, 2008
6ya staff
SOURCE:
TV WONT POWER UP
Replace the power regulator board as card basis. Its oscillator IC has been damaged. It can't be replacale.
May 07, 2012 | Olevia LT23HVX 23 in. LCD Television
RED LIGHT COMES ON,BUT WON,T POWER UP
Check its power supply regulator and main baord for fault. If there is any short circuited components on the main digital baord, this type of fault will occur.
My lt23hvx power button does not work. I keep pressing the power button to turn on and it will not turn on
If you're trying from the remote control, then try from the TV and see if it works. Or vice versa... Also, make sure the TV is plugged in (you would be really surprised to see how often this is a problem).
If there is no noise and no lights, then odds are your power supply is faulty. For that tv, you're looking at a replacement of less than $100.
Cheers, -SJ
Mar 08, 2011 | Olevia LT23HVX 23 in. LCD Television
I have 19" Olevia LCD TV and the red power light comes on when you plugged it in but the TV DOES NOT power on
You only have 5v standby voltage circuit working. The problem can be i nte main power supply or the main control board that send the signal to the main power supply to turn on. Those are the two place to look for.
http://en.wikipedia.org/wiki/Capacitor_plague
Nov 03, 2009 | Olevia LT23HVX 23 in. LCD Television
Red lite comes on but tv will not power up.
Follow the solution for service port 'jump start' with a usb plug. Plug your cell phone charger in next to the TV. Touch the metal prongs of the service port with the metal part of the usb until you get a brief 'flash' on the TV. Then turn on the tv set. It takes patience and a flash light to do this, so you can see what your touching, as my husband couldn't get it to work, but I could.
Apr 20, 2009 | Olevia LT23HVX 23 in. LCD Television
My olevia LT23HVX does not power on
Try unplugging and replugging after waiting.
Jun 13, 2008 | Olevia LT23HVX 23 in. LCD Television
Can't turn tv on
Follow the solution for service port 'jump start' with a usb plug. Plug your cell phone charger in next to the TV. Touch the metal prongs of the service port with the metal part of the usb until you get a brief 'flash' on the TV. Then turn on the tv set. It takes patience and a flash light to do this, so you can see what your touching. This will not turn on the set. You still have to do this yourself after the flash.
May 08, 2008 | Olevia LT23HVX 23 in. LCD Television
Televison & Video Logo
7,707 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
