Clearing Memory I need to know how to clear the memory on a panafax UF-770.
Please HELP!
Lily-put
New on the job- no manual for the panafax uf 550- need to clear memory!!1 Help!!!
if you do shipment set it will reset to factory specs, be carful you dont press the wrong thing in service mode or you may have irriversable problems.function 7 monitor monitor monitor monitor #
You can't post conmments that contain an email address.
Your killing a fly with a sledge hammer. If you do a ALL JOB clear from test mode 6 instead of SHIPMENT SET... you wont loose all your one-touches or fax parameter settings.
Your modem/fax board is most likely bad. there is a relay on that board that has probably failed. It is stuck. I doubt it can be made to work. those are really small relays on those boards.
There should be a memory clear procedure in the menu to stop that.
You will have to reenter the time date, your phone and business name once you clear the memory.
I dont have a book for that particular machine, but faxs do have a memory clear feature for lock ups like that.
how do you go into service mode???
