2001 Mercedes-Benz C-Class Logo
Posted on Mar 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Oil consuming i have a mercedes benz c220 cdi year 2001 i have made around 150 000 km.i have changed the oil before 8 000 km and now it needs 1 ltr to add.is this consuming of oil normal or something goes wrong with my engine?
Anonymous
Level 2:
  • Expert 54 Answers
  • Posted on Mar 04, 2010
Anonymous
Expert
Level 2:
Answers
54
Questions
Helped
11684
Points
139
2answers
My c220 1995 with 107,000 mercedes consumes 1lt every 1500 km but it does not have exaust blue smoke
Check for external oil leakage along right side of cylinder-head. Oil can burn on exhaust in such small amounts you will not see it or smell it.
Maps of distribution fuses mercedes-benz c220 cdi
hi
you can use any fuser you can find
on eletrical equipment shops
2helpful
How many liters of oil as the engine for MERCEDES BENZ C220 WDB203?
For 2002 Mercedes-Benz C 220 CDI WDB203, engine code 611.962, the engine oil capacity is 6,5 liters, with oil filter replacement.
I would like to buy c220 cdi avangrade year 2001 what is the most importance think i must cheack on that car ? Buy the way i`m from malaysia the milelage of the car is around 90,000 km.
It's cant say any particular thing as every thing are very important, so best way to do talk with owner and get the car to Mercedes dealer workshop which is the near by your place and tell service adviser your requirement then they will give you a very advance report that's the best way to do it becouse if any simple thing wrong it will cost you too much money for fixing, if you spend little money for checking it worth for you than spend big money for repair, Is this information helped you?
What kind of oil should I buy for c220 cdi 2000
Look under the hood, either on the oil fill cap or a name plate near the radiator
1helpful
2answers
6helpful
4answers
2003 mercedes C270 CDi auto gearbox fault
mercedes c220 cdi 2004 140k done gets stuck in gear then have to turn of ignition to get it working again. had recently had the gearbox serviced
Car problems
Sounds to be a loose or corroded wire/s at either starter motor or at battery fusible links.
Also check the earth strap (Cable) between engine and bodywork.
Hope this helps, MMP
Top Mercedes-Benz Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Arnie Burke
Arnie Burke
Are you a Mercedes-Benz Expert? Answer questions, earn points and help others
