Open the freezer compartment loo for ice build up on floor of frezer especally towards rear behind back panel. sounds like you have a clogged/frozen defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials)
Water is collecting on the shelves and underneathe the crisper drawers, then freezing, i don't see where the water is coming from, got any suggestions?
Michael
The regrigerator has water dripping onto the shelves and on the lower portion of the refrigerator into the bottom drawers also.The correct temperature setting is right.how do i fix this.
It has been a week now and the old frig is working just like new. Thanks for the help, I almost went out and bought a new refrig. Thanks for savings me several hundred bucks
Check out these tips...they can help you figure out what is going wrong with
your refrigerator
Refrigerator
not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost
Timer Problem
Water
Running in refrigerator from Freezer
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
I'll give it a shot, Thanks for the recommendation. I'll let you know what happens.
I used a turkey baster with hot water from the kitchen tap.
Hi, i have the same problem with my refridgerator,leaking water, i was told by someone it is a clogged drain hose and to use a hair dryer on it, but reading this solution you are saying to unscrew the back panel in freezer section to access the problem, am i right on this or is there a need to do this?
I tried your recommendation and took off the bottom panel in the freezer section and sure enough there was a block of ice under it plus the drain hole was solid ice too. I did remove all the ice from the freezer bottom and used boiling water to thaw out the drain hole. The water is flowing freely now. There is one question I do have. Could you explain the suggestion for wrapping copper wire around the heater and dropping down the drain hole for me? I have no idea where the heater is. I will reply back in a few days and let you know how my frig is working thus far.
Hi, I have notice water on the bottom drawers where I kept the fruits and vegetables. I don't know where is the drain pipe, maybe it is clogged. How do I undo the clog and where do I open the drain hole? The freezer gets extremely cold even the number is at the lowest level. Is there anyway to correct the problem. Thanks!
The regrigerator has water dripping onto the shelves and on the lower portion of the refrigerator into the bottom drawers also.The correct temperature setting is right.how do i fix this. thanks b.hall
the refrigerator has water dripping onto the shelves and on the lower portion into the bottom drawers. can you help me fix this problem.
Michael
I have water leaking on my shelves and under the crisper draws then it freezes.
I have water leaking on to the shelves and under the crisper draws the it freezes
